Muncie 4 speed problem?? - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Jun 1st, 06, 07:51 PM
dgmz28 dgmz28 is offline
Default Muncie 4 speed problem??
Hello, I have a Muncie M22 in a '69 camaro...the problem is, it pops/jumps out of 2nd gear when going down a hill w/o accelerating, i.e. using the engine compression to slow/ brake the car. It doesn't jump out of gear when under normal acceleration.Also no grinding when shifting, thru all four gears.
What could the problem be? thanks!
Old Jun 1st, 06, 08:13 PM
kilroy396 kilroy396 is offline
Tom
Default Re: Muncie 4 speed problem??
I had a M21 in a 69 SS396, with the same problem, I was told it was a bad
2nd gear syncro
Old Jun 1st, 06, 08:32 PM
Farm Boy's Avatar
Farm Boy Farm Boy is offline
Steve
Your Muncie is wearing out. Second gear, and the slider that connects it to the hub, have worn enough that it pops out of gear. A new Torque Lock slider is fairly inexpensive and will stop the problem for a while if your second gear is not too bad.
A longer lasting solution would be to rebuild it with all new gears, hubs, blocker rings, bearings, and small parts. It will be more expensive but your Muncie will last another four decades.
Either way the transmission must be disassembled.
Steve
1967 Camaro
I drove it for the first time in 1972 when I was 15.
1956 Bel Air Sport Coupe
Better looking than a '56 Ford or Plymouth.
Old Jun 2nd, 06, 03:53 AM
Unreal Unreal is offline
Gary
Why use the engine to decelerate? Brakes are a whole lot cheaper to replaced than clutches and trannies.
Old Jun 2nd, 06, 05:52 AM
John3366 John3366 is offline
I have a similar problem. I was told is caused by wear on the engagement teeth for 2nd gear. The teeth are normally rounded or slightly pointed at the front and then have flats on the sides. As the flats receed back from wear, the slider can pop off when not under load. To fix the problem, 2nd gear has to be replaced. The slider could be contributing as well, both should be replaced. At least this is what I was told.
John Wolfe
Lemans Blue 69 X33D80
Old Jun 2nd, 06, 09:06 AM
dragon0123 dragon0123 is offline
Mark
yup/.. trans need to be rebuilt.. at least those 2nd gear pieces. while your at it have them look at 3rd too casue thatll be the next to go..
Mark
1967 Camaro
My Photobucket >> http://s145.photobucket.com/albums/r239/camarodragon/
Old Jun 3rd, 06, 04:18 AM
Thumbs up Re: Muncie 4 speed problem??
Thanks to all that gave input & suggestions...by major conscienous it sounds like 2nd gear & the slider is the culprit. For how often I run it (1000-1500 miles) a summer, I will replace just those pcs.
thanks again for your help.
Dave
Old Jun 3rd, 06, 05:01 PM
Where can I purchase the "torque lock "syncro to fix my prob?
thanks
Dave
Old Jun 3rd, 06, 09:03 PM
Larger Dave Larger Dave is offline
Dave
Cool Re: Muncie 4 speed problem??
I doubt if the gears are worn to the point of it popping out of gear. But I'll wager the syncro's are shot. I would definitely rebuild it if you are familiar with the procedure; particularly if you have a numbers matching tranny. Otherwise you can purchase a rebuilt one with all new replacement parts installed ready to run on line and send them your core. When I was younger we used to swap Muncie's after every missed shift, so there are very few numbers matching four speeds around. If yours is a numbers matching it can be rebuilt by any competent shop (i.e. dealership), as I wouldn't let it out of my sight.
Larger Dave
Old Jun 4th, 06, 06:04 AM
Get in touch with Craig Wright, I think his site is wrightconnection.net. He rebuilds Muncies and sells parts out of California. He's a real good guy and talked me through rebuilding mine with some good pointers. You can also find detailed rebuilding instructions on the web. It's fairly easy and takes a few hours to assemble after you've got it a part. Good Luck
John Wolfe
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: Muncie 4 speed problem??
Location
Location
First Name
Human Verification
Similar Threads
Muncie 4 SPEED ID SCHOON Transmission & Driveline 5 Mar 12th, 06 07:49 AM
change transmission for one 4 speed Muncie Violent.C Performance 8 May 2nd, 04 08:09 PM
Muncie 4 Speed Noise rpol78 Performance 5 Mar 31st, 03 06:26 PM
