67 RS hideaway headlights problems - Team Camaro Tech
Thread Tools Display Modes
Old Jun 4th, 06, 03:20 PM
Willem Willem is offline
Tech Team
Willem
Angry 67 RS hideaway headlights problems
Hi,
I can't solve the problems I'm having with te RS wiring. I have the electrical overview of the wiring, but I can't crack the problem. I checked the relays according to the manual. Both motors were taken out and are working now (some binding), the limit switches are all working, the orange, light blue and brown are energized. I have 12 v (when lights on) at the motors, but they don't move. I have 12v at the relays when I want to close the lights, but not at the motors?
Any ideas?
Thanks, Willem
1967 RS Camaro
http://www.cardomain.com/ride/2355846
Old Jun 4th, 06, 06:28 PM
CFunK CFunK is offline
Call me Funk
Default Re: 67 RS hideaway headlights problems
Is the key in the ON position? The doors won't operate with the key in the OFF position.
Old Jun 4th, 06, 06:38 PM
Camaro67_rcl's Avatar
Camaro67_rcl Camaro67_rcl is offline
Rick
Are the limit switches being pressed in ? I had one that wasn't & need to be adjusted. As CFunK said - key has to be in "ON" position for motors to close doors
Old Jun 4th, 06, 11:02 PM
Tech Team
Willem
Yes, the ignition is in the ON position (12V brown diode wire) and the limit switches are working properly.
1967 RS Camaro
Old Jun 5th, 06, 04:39 AM
19673L4P 19673L4P is offline
randy
Did they ever work?
What has been done since they worked?
If as you say you have 12 v at the motors (working and not over tightened) you might have limit switches switched (wrong side of the motors) or you are not getting grounds on the switches.
Old Jun 5th, 06, 05:13 AM
Tech Team
Willem
I haven't driven the car for a while, they worked great before. I didn't change anything on the setup.
I checked the wiring on the switches top/down, they ground when depressed
When ignition in ON position (brown wire), light switch in OFF position I get a few volts on Relay 2 and 3 on the light blue wire. Is that normal?
1967 RS Camaro
Old Jun 5th, 06, 11:37 AM
Camaro Dave Camaro Dave is offline
Replace the Diode, it sounds like current is flowing the wrong way back to the relay #2 and #3. Also check all the ground wires on the limit switches to the radiator support.
67 RS Camaro 327/ 350 Holley 650cfm > Edelbrock Performer Intake > Pertronix Ignition > Accel Super Stock Coil and Wires > Hedman Hedders > Hotchkis Performance Springs > 15" Rallys all around
Camaro buds until the end!!!
Old Jun 5th, 06, 01:11 PM
Tech Team
Willem
I'm not sure what you're saying Camaro Dave since the brown wire has the diode, the wire is coming from the ignition. The light blue wire coming from light switch gets now (in the OFF position) current from relay 2 and 3
1967 RS Camaro
Old Jun 5th, 06, 11:48 PM
Willem replace Relay #2 and see if that solves the problem.......It's either the relay or an open with the diode. You might have to try a few things to narrow down the problem.
Old Jun 6th, 06, 11:07 AM
Tech Team
Willem
I've replaced relay 1, 2 and 3 with no positive result. I'll hook up the motors and tinker around a bit.
1967 RS Camaro
  #11
Old Jun 7th, 06, 02:02 PM
Tech Team
Willem
Problem solved!!!
Cleaned up all the terminals motors/limit switches/relays/wiring with contact spray. Opened up one of the motors which was stuck again. The axle coming out of the motor was rusted and got stuck in the bronze sleeve.
1967 RS Camaro
  #12
Old Jun 7th, 06, 06:09 PM
Rick
Glad you found the problem, best schooling is learning it as you do it
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: 67 RS hideaway headlights problems
Location
Location
First Name
Human Verification
Similar Threads
67 RS Hideaway problem Deangelo66 Electrical & Wiring 5 Apr 15th, 06 09:26 AM
Hideaway headlights Basser Troubleshooting 2 Mar 30th, 06 06:29 PM
Strange Headlight Problem(s) Straight-line-69 Electrical & Wiring 14 Aug 25th, 05 08:45 PM
Goodmark Quarter Panel Problems!!!! Liveinaz Body Shop 7 Jun 28th, 05 09:10 PM
MSD PROBLEMS RAY NORLIN Troubleshooting 3 Oct 9th, 00 03:40 PM
