 5thgen.jpg - 4890 Bytes
Fifth Generation Discussion forum for the newest Camaro
Old Jun 6th, 06, 09:38 PM
SooperDave SooperDave is offline
Dave
Default Will GM learn from Ford mistakes?
According to Motor Trend, the new Shelby GT500 has a curb weight of 3944 lbs!!!! That's crazy I don't car how much power it has. GM- please - if you build a new Camaro keep the curb weight well below 3500 lbs.
68 Z/28, 406 small block, 10.75 CR, AFR 210, Vic Jr, solid roller
An original Z/28 with the 302 set aside for now
Old Jun 6th, 06, 10:05 PM
WildBillyT WildBillyT is offline
Bill
Default Re: Will GM learn from Ford mistakes?
How much did an LS-6 Chevelle weigh? Isn't it less than that?
Old Jun 7th, 06, 07:49 AM
OverAnxious OverAnxious is offline
Hopefully.
Speaking of the GT500 - checkout this review of the GT500 and the C6 Corvette
http://5thgencamaro.blogspot.com/200...chevrolet.html
Joe
Over Anxious 67 Camaro RS/SS L78 / 5th Gen Blog / Modern Camaro (5thgen.org) Forums
Michigan Classics - Classic and Muscle Car Enthusiast Resources
Hot Rod Search - Google for Gearheads
Old Jun 18th, 06, 06:46 PM
tjlarge tjlarge is offline
Tom
The current weight of the Camaro is just under: 4000 lbs , according to Motor Trend Magazine (and confirmed by insiders.....). Of course this is the engineering estimate which can be off by a couple hundred pounds - usually on the heavy side. Expect the convert to weight a bit more (~+200 lbs).
The problem is that this is a "global" platform from which the Camaro and a few other variants will be built. It needs to meet all kinds of crashworthyness regulations from around the world and it takes a bunch of extra metal in odd places to do that. There may be plenty of opportunities for a racer to lighten the car - but the stock folks will be a bit on the heavy side..... There is a saying that "mass begets mass" which means the heavier something is, the heavier you need to build a structure to hold it - it feeds on itself !!
Tom - Oxford, MI
GM Powertrain
'68 Camaro Coupe 396/375HP SS
(Cloned Car - Real 375 HP Engine )
Old Jun 19th, 06, 12:25 PM
South Side Goons & Hitmen South Side Goons & Hitmen is offline
Gold Member
I agree with TJ.
In today's world a car must meet all kinds of safety and crash requirements. Plus you now have power everything, deluxe A/C, stereo surround sound etc. etc. etc. This is why the new Mustang weighs so much. This is also why the regular 2006 Corvette inspite of giving up about 100 horse power to the Mustang beat the 'Stang by 1/10th in the 1320 because of the 600 or so pound weight advantage.
Remember the Mustang LX 5.0's of the very late 1980's. Especially the trunk type/notchbacks. These cars were around 2900 lbs or so and had about a 400-500 lb weight advantage over the 5.7L IROC-Z's. Even though the IROC had about 20 more horsepower that mattered little when you give up 400-500 lbs.
Old Jul 20th, 06, 07:05 PM
On the weight and global structure issue, at least all the players have to abide by the same rules
Originally Posted by South Side Goons & Hitmen
I agree with TJ.
Those 87-93 LX 5.0 Mustangs were the best bang for the buck!
Joe
Old Jul 20th, 06, 08:48 PM
Brackneyc's Avatar
Brackneyc Brackneyc is offline
Craig
No, they haven't learned from Ford's successes either. GM is still out there trying to re-invent the wheel.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old Jul 20th, 06, 09:50 PM
tired68 tired68 is offline
deleted
Similar Threads
Ford 9" direct swap to 68 Camaro Not2LateForThis68 Transmission & Driveline 13 May 16th, 06 05:06 PM
Ford TKO 600 conversion issues for my '69? 69RSCONVERTIBLE Transmission & Driveline 8 Jan 23rd, 06 02:43 PM
Wow guys.. looks like GM is not the only guys in trouble! garfield Bench Racing 13 Jan 22nd, 06 11:05 AM
9" Ford Swap Info Dans67 Brakes, Suspension & Steering 12 Dec 4th, 05 07:26 PM
weight of a 67' camaro? CamaroNOTcamero Performance 16 Sep 17th, 01 08:12 PM
