 Ground Up Restorations
Second Generation 1970-1981
Old Jun 18th, 06, 06:34 AM
tomspo04 tomspo04 is offline
Tech Team
Tom
Default Converting 70 Alt to one wire
Can anyone tell me how to convert my 70 external regulator Alt to a one wire internal regulator set up? I see that it's been addressed on 1st gens, but haven't been able to fine an early second gen. Thanks, in advanve.
Tom
Old Jun 18th, 06, 10:59 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Re: Converting 70 Alt to one wire
Have you inquired at www.nastyz28.com they are more of the 2nd generation folks there. Im sure some of them have done it. Most of us are first gen in here but they might be the same setup, Im not sure but someone will comment soon.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto.
Our Camaro Webpage
Photos for viewing
Learn How To Post Pics here
Old Jun 19th, 06, 12:34 AM
Tech Team
Tom
Click, Thanks, I'll try over there. At the same time, maybe someone here can help.
Old Jun 19th, 06, 01:19 AM
undee72Z undee72Z is offline
One wires are simple, just the big wire to the original charge wire, to the battery or horn relay, but they are not the best. One is the GEN light will no longer work, plus other reasons, see here
http://www.madelectrical.com/electri...threewire.shtm
It would be better to use a internally regulated alternator wired as a 3 wire.
Converting is easy, see pic below, works for 10SI's too.
For more info and some part#'s go here
http://www.madelectrical.com/electri...elcoremy.shtml
If you are electrically challenged or do not want to cut your original harness, you can get conversion kits that make converting to a internally regulated alternator a "plug and play" deal, see here http://www.americanautowire.com/prod...rsion_Kits.cfm
Greg U
My 72 Z
Undees 70 SS, street driven drag car
Similar Threads
Draining battery, Possible alternator Need help! mnm99 Electrical & Wiring 33 Jun 2nd, 06 01:12 PM
1 wire alt question Kwondo1967 Electrical & Wiring 2 May 15th, 05 07:40 PM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 08:02 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 02:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 02:57 PM
