383 combo feedback - Team Camaro Tech
Old Jun 19th, 06, 11:33 AM
67 vert 67 vert is offline
Tech Team
Dave
Default 383 combo feedback
350 block 30 over. 400 crank, 400 rods, flat top trw pistons, dart 215 74 cc heads ,xe 284 camshaft 507/510, rpm intake,780 cfm carb, msd 6al box,hei, 350 turbo,3000 stall, 373 gears. 1973 camaro. All parts have been machined and clearaned approx 9.5 comp. I hope this makes a baaaad street car. What do you think.
Dave
Old Jun 19th, 06, 12:01 PM
BPOS BPOS is offline
Al
Default Re: 383 combo feedback
The only thing that jumps out at me are the 400 rods. At the very least make sure you put high quality aftermarket bolts in them. It's not the rod LENGTH thing so much to as the fact that the 400 rod isn't known for being the stoutest piece, although many have used them without a problem. Sounds like a stout street motor to me.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Jun 19th, 06, 12:18 PM
camaro_fever68's Avatar
camaro_fever68 camaro_fever68 is offline
Ray P.
It's a decent combo, but if it were mine I would have went for a 200cc head with a 64cc chamber. Make sure to put ARP bolts in the rods as mentioned above.
Ray
Old Jun 19th, 06, 12:22 PM
67SS&99SS 67SS&99SS is offline
Andy
Check out this month's chevy high performance. They just tested 8 different sets of heads on a 383, and the results were eye opening. The 215 CC darts did pretty good with the xe274 cam; 450 hp and 468 ft lbs. However, they said that these heads really shine on a larger displacement sbc, over 400 c.i. and that a smaller cc head would be better suited for a 383. That xe284 may hurt your low-mid range torque as well, but it would probably make more peak hp than the xe274.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
My Cars
Old Jun 19th, 06, 02:12 PM
Eric68 Eric68 is offline
Eric
I would try to get the compression up to about 10.5:1 with that cam and those heads.
Other than that just makes sure the rods will be strong enough. Those pistons tend to be on the heavy side.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old Jun 19th, 06, 04:39 PM
Tech Team
Dave
Thanks I wont be turning it any higher than 6 k. I hope it stays together. Yes I used arp rod bolts
Old Jun 19th, 06, 04:40 PM
Tech Team
Dave
I didnt want to pay 500 for a dyno test. I hope it has more than 400 in the H.P and TRQ
Old Jun 19th, 06, 06:12 PM
Eric
I don't think 400 HP will be a problem. Should be more like 425 IMO.
Similar Threads
383 combo meanZ Performance 7 Apr 21st, 06 01:04 PM
383 Combo Going to Builder murrayo Performance 13 Apr 15th, 06 01:42 PM
Interesting New 383 Combo! Motorhead62 Engine 18 Nov 10th, 05 07:48 AM
383 combo needed...plz help 72camaross Performance 32 Sep 30th, 05 08:38 AM
A few 383 combo questions SlickCamaro69 Performance 2 Sep 14th, 02 07:19 PM
