Is This a Z-28 - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Jun 22nd, 06, 08:04 PM
onewickedcamaro onewickedcamaro is offline
Tech Team
Cool Is This a Z-28
I am thinking of buying this 1969 z-28 camaro. I need to know if it is a Z-28 car. It has no engine trans or rearend on the car so I cannot give you any of the numbers, Here is the cowl info
ST 69 12437
TR 718 Nor 140852
11D 52 52 PNT
Vin # is 124379N551391
Any help would be great.
What do I look for to indicate it is a Z-28????
Old Jun 22nd, 06, 08:11 PM
caliz caliz is offline
Default Re: Is This a Z-28
i dont think that norwood had the x code on ealy z
so every thing on the trim plate as nothing on it to say that its a z28
Old Jun 22nd, 06, 08:13 PM
Westonz28's Avatar
Westonz28 Westonz28 is offline
Might have something behind the rear seat, x3,x1,x7 etc. Maybe to early for that also. Just a though.
1967 RS L30/M20 2nd owner, numbers matching
1968 SS/BB 396, Daughters Camaro, true BB car not numbers matching.
1968 Coupe 2nd owner, Sons Camaro numbers matching
1969 RS LM1 2nd owner, numbers matching, in body shop now. My Camaro(it was my turn)
1966 Buick Special Conv. numbers matching V6, fun car to drive around in.
1970 Camaro coupe, 350 L65, 350 auto, numbers matching,
1968 Chevelle Malibu, 327 L30, 3 speed on the tree, third owner.
Old Jun 22nd, 06, 08:34 PM
BelAirBob BelAirBob is offline
Bob
Should be an exhaust plate on the driver's side rear frame rail at about the 1 o'clock position. The plate is roughly 3 inches by 2 inches tall, and is spot welded to the frame rail.Also, car should have front disc brakes and prop valve. There should also be a residual brake valve on the frame, under the drivers seat area. (in most cases, anyway). Speedo cable should penetrate the firewall to the LEFT of the master cylinder if looking from the FRONT of the car. If no cable, there should be a hole just above the throttle linkage that is roughly 1 inch in diameter. This firewall hole was unique to the Z and big block cars. Car should have a 12 bolt rear with four springs (most of the time) with a date range just slightly before the build date of the car, so maybe sometime in October. All Z's had four speed Muncie transmissions, so look for the frame linkage and/or clutch pedal. Car should have a single 3/8 fuel line as well. If the car does not have PS, the pitman arm should be roughly 5 inches long, and the spindles should be the "short knuckle" versions. This is the standard "quick ratio" N44 steering found on the Z cars. Finally, as was mentioned, look behind the upper rear seat cushion. On the bulkhead, there should be "X7" or "X3" written in yellowish crayon. This is generally found on the passenger side, but I have seen it on either side. (Mine is just to the right of center on the driver's side.) These are many of the clues to look for, but nothing beats having the original drivetrain and documents to verify the car's pedigree. The car is an early 69' build based upon the VIN. X codes on the trim tags (X77 or X33) did not start until December of 68' for the 69' units. The 'X coded" cowl tags help to verify these cars as the real deal, although regrettably, they are faked pretty frequently nowadays. Good luck in your search. Hope you found a real one.....
BelAir Bob
69 Z28 X33 D80 Dusk Blue
69 Z28 X33 Rally Green
http://www.belairbobs.com
Old Jun 22nd, 06, 08:47 PM
Tech Team
Can anyone tell me what the cowl tag info. means? Like what color the car was etc....
Old Jun 22nd, 06, 08:57 PM
Bob
Car was Garnet red, with red standard bucket seats (Neat!) Built 4th week of November, 1968. Other numbers are body sequence numbers used by the factory.
Here's the breakdown-
69- Model Year
12437= Camaro Coupe V8- denoted by VIN
NOR- 140852- Body sequence number
11D- November, 4th week
718- Standard buckets seats
52 52- Garnet red paint, no vinyl top
BelAir Bob
Old Jun 22nd, 06, 10:31 PM
car_habit car_habit is offline
Ron
All good hints, but I would do a title search at your local DMV. Contact as many past owners as possible, and pray they are truthful. If the original dealership is still around, they may have some papers on the car. Then offer 1/2 what they are asking unless they have good documentation. In my opinion there are too many fakes out there to take a chance with big money. Its way too easy to claim a non x coded car as something it isn’t. Every LA car I’ve seen lately is an SS or RS or Z…Just be careful.
Old Jun 23rd, 06, 08:19 AM
satz28's Avatar
satz28 satz28 is online now
Rob
I just wanted to point out that the brake propotioning valve can also be mounted on the master cyclinder.
In addition, you can have a Z-28 and not have a tach.
These are 2 items that people think has to be on the car to "prove" you have a real Z.
I have an X77 with the valve attached to the MC/booster, and no tach.
Old Jun 23rd, 06, 10:30 AM
Bob
Hi, I was referring to the frame mounted residual valve, not the prop valve. You are correct, a Z did not need to have a tach ,posi rear, console, or cowl hood. My car was a flat hood, no console, center fuel gauge car. As an X33 D80 car, it also had trim style package, and both spoilers, but was otherwise a pretty plain Jane Z. Not even power steering! Cheap and fast was the order of the day I suppose.....
Here's a pic of the resid valve I was talking about. Should be mounted on the frame under the driver's seat....
BelAir Bob
Old Jun 23rd, 06, 12:22 PM
Pacecarjeff Pacecarjeff is offline
Jeff
Check for the original tire decal. (on the glove box door)
Z/28's had 15" wheels.
carefull though - those can be easily faked.
Old Jun 23rd, 06, 12:42 PM
satz28's Avatar
Rob
I didn't think that was a real indicator of a Z. I thought I read some where that the jury is still out of the usage of this valve. My (68 11A) 69 Z does not have this valve.
Old Jun 23rd, 06, 12:43 PM
Bob
Hi, Yes it is hotly debated, but most (not all)had the valve.
BelAir Bob
Old Jun 23rd, 06, 12:50 PM
Jeff
Didn't the SS cars have that valve also?
Old Jun 23rd, 06, 01:20 PM
Bob
Hi Jeff, Yes..Depending on who you talk to,the vast majority of disc brake cars had the valve. This would include the SS and Z28 cars. Some drum brake cars had it, and as has been mentioned, some disc cars did not. By and large though, if it was an SS or Z28, it had the valve. I realize that some of the exceptions mentioned exist,but of the dozens of SS and Z cars I've looked at over the years, ALL had this valve.
BelAir Bob
Old Jun 23rd, 06, 01:38 PM
Jeff
That is what I thought...
So this would NOT be a good thing to look for, to determine if ths car is a Z/28.
