piston to deck height clearance for sbc - Team Camaro Tech
Thread Tools Display Modes
Old Jun 28th, 06, 08:05 AM
67SS&99SS 67SS&99SS is offline
Andy
Default piston to deck height clearance for sbc
What is the typical piston to deck height clearance for a 350 block? Is it .040"? I am putting together a 383 with my engine program and with 64 CC vortec heads, a .040" depth for the piston in the bore, 12 CC dished piston, and a .015" head gasket, I am getting 9.96:1 CR which is exactly what I want. I want to stay as close to my target of 10:1 CR as possible. Am I right in assuming a .040" clearance? How much could it be off from that? FYI, have a 1970 350 4 bolt main block that has never been machined.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
My Cars
Old Jun 28th, 06, 08:17 AM
JimM JimM is offline
Jim
Default Re: piston to deck height clearance for sbc
particularly with a stroker, deck clearance HAS to be actually measured, don't assume.
A stock engine generally has around .025" deck clearance.
When I did my stroker, at final assembly it measured ZERO deck! This was an undecked numbers block, with scat crank & 6" rods, and SRP pistons. I ended up throwing away a set of 1094's and using a different gasket to get .040" piston to head (quench) clearance.
Checking deck ht is easy, just use a straightedge and a feeler guage.
Old Jun 28th, 06, 08:24 AM
rojo rojo is offline
Robert
I agree with Jim, you need to measure it. My '69 was .025 and the '67 was .045. The '67 must have some sort rebuilders pistons in it.
Edit: I reread the post and saw "engine program". At first I thought you were bolting your heads on now.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...T56 Magnum, 3.73 Moser 12 bolt
TC member #18
Old Jun 28th, 06, 08:58 AM
Andy
Thanks guys. It will definately be measured when it is assembled. I hope that it will work out so that I can easily obtain my 10:1 CR. I should be able to play around with head gasket thicknesses to get it pretty close, right? Here is a dyno graph of my current setup. The higher numbers are open headers and the lower are 2.5" dumped exhaust. I achieved this with a hydrallic flat tappet off the shelf cam, vacuum secondary carb, clutch fan, production water pump, power steering, and the 170 CC combustion chamber of vortec heads
My Cars
Old Jun 28th, 06, 09:45 AM
NER perf NER perf is offline
nick
im confused .are you saying pistons are 040" in the hole or head deck to block/quench side of piston is 040"away? those are two different measurements if you run that mototr with the pistons 040"in the block it will rattle itself to death .youd run better with more compression and better quench for sure
84 Mustang Hertz Rent-a-Car
400" LSX 9.44@146 (w only 1.44 60 ft) All Motor
In Denver on Pro 275's
Powered by my 7 yr olds Engine program
Old Jun 28th, 06, 09:50 AM
Jim
I think he's asking if his assumptions are in the ballpark.
Personally, after my experience, I wouldn't even buy head gaskets for a stroker untill I've put a piston in and measured the deck clearance.
As long as you can gasket for .040 piston to head, the actual deck clearance won't effect your compression ration.
Old Jun 28th, 06, 09:55 AM
Andy
Thanks for the reply, but like Jim M said, I am wanting to know typically how far a piston is down in the bore when it has reached its full stroke. I understand those numbers are two different numbers. What should be my total overall piston to head measurement? Should it be between .040 and .050? I was saying .040 for the piston in the bore as baseline number since I am unsure of what the spec number should be. I understand that it can fluctuate, but I am just wanting a good ball park figure.
My Cars
Old Jun 28th, 06, 09:56 AM
Andy
Thanks for the info Jim.
My Cars
Old Jun 28th, 06, 01:40 PM
DZ Fool DZ Fool is offline
Danny
Piston to Head is a combination of measurements . Piston to deck is just that , how far in the bore the piston is in relationship to the block. If you are 40 in the hole and a .015 head gasket your quench is .055 Which is allot
69 Rally Sport-Z/28-Orange/Wht stripes-White vinyl-Ivory Houndstooth Interior Fold down seat Early 69 ( 11/12/68) 5494xx vin
67 RS Coming Soon
http://www.chitownracing.com/forums/...572a4a5071.jpg
http://www.myspace.com/danny_db
Old Jun 28th, 06, 01:46 PM
Andy
what should the total quench be? .035-.045?
My Cars
  #11
Old Jun 28th, 06, 01:53 PM
eville eville is offline
Team Member
Steve
from what I understand .035-.045" is ideal. There is a lot of good reading about this topic on this site if you use the search feature.
Do as JimM said, don't buy head gaskets til you measure the piston to deck height. There are a lot of available thickness gaskets out there.
Good Luck.
Steve
1968 Coupe., filled with cool stuff from Tremec, Moser, Ron Davis, Speedtech, ATS, Hotchkis, Forgeline... blah blah blah
Check it Out Here
  #12
Old Jun 28th, 06, 06:47 PM
pdq67 pdq67 is offline
Banned
Smile Re: piston to deck height clearance for sbc
I figure that GM tried to make our old motors at .025" down in the hole piston b/c they used .020" steel shim headgaskets on them.
For a .045" quench which as we have found out tend's to be like at the max. WE want for a hi-po motor.
pdq67
  #13
Old Jun 28th, 06, 08:59 PM
Andy
thanks for all of the help guys! i dont plan on buying gaskets until the short block is completely assembled and I will talk to my engine builder about it.
My Cars
Team Camaro Tech > All Generations > Performance      Current Topic: piston to deck height clearance for sbc
Location
Location
First Name
Human Verification
Similar Threads
Need engine assembly tips JimM Performance 83 Apr 16th, 06 05:10 PM
Deck Height vs. Piston Height 68Camaro396/375 Engine 1 Nov 30th, 05 04:54 PM
Did i degree my cam and check my piston to valve clearance correctly?? cody Performance 5 Jul 13th, 03 08:35 PM
Deck height questions, please help Camaro76350 Performance 3 Dec 17th, 02 03:23 PM
piston to valve clearance 69 Man Tech 2000 3 Mar 27th, 01 06:24 PM
