Bug Hunt Computer related problems
Virus warnings - Technical help.
Old Jul 4th, 06, 08:27 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Spyware alert or virus,
My Norton detected a virus yesterday and stopped it and deleted it but this outfit (dont go to it) (www dot syssecuritysite dot com) took over my Internet Explorer home page and wont let me change it. Ive run my spy check and ad aware programs but nothing touches it. Anyone run into this before? I cant even use my IE for any other site, its locked up at this jerk outfits site.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto.
Our Camaro Webpage
Photos for viewing
Learn How To Post Pics here
Old Jul 4th, 06, 08:50 AM
al8apexer al8apexer is offline
Default Re: Spyware alert or virus,
never heard of it, never will
G5 here
you could always just get a mac and avoid all that drama/concern in your life ....
Jim Rohn
Scottsdale, AZ
70 M22 Z28
34 Ford original
Old Jul 4th, 06, 09:15 AM
Rack Man Rack Man is offline
Dan
Well, I would try running several different anti-spyware programs....I usually run three myself...
1. Adaware
2. Spybot
3. Ewido
I also run "toolbar cop" which removes any extensions from IE
If all that fails I simply use the restore feature on my Computer and restore it back to an earlier point in time...Like the day before the virus hit..
To do this (at least on my puter):
START
PROGRAMS
ACCESSORIES
SYSTEM TOOLS
SYSTEM RESTORE
Then simply follow commands in system restore
Good Luck!
Dan
Old Jul 4th, 06, 09:27 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
A google on the url shows none of the spyware listed will stop the high jack... Many pages I found are recomending running something called SmartfraudFix. Click this to download it. I have not tested it but the tool was found linked on fairly reilable sites like tweaks.com http://siri.urz.free.fr/Fix/SmitfraudFix.zip
The instructions are
Extract the content (a folder named SmitfraudFix) to your Desktop.
Open the SmitfraudFix folder and double-click smitfraudfix.cmd
Select option #1 – Search, by typing 1 and press "Enter"; a text file will appear, which lists infected files (if present).
The System Restore is also a great way to go back before the infection but a lot of this crud is not effected by design. You may go back before it installed itself but as soon as you reboot it reinstalls. I'm not saying this one is this way, just throwing out a be aware if you restore back and it comes back. Also you can loose legit installed software using System Restore...
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Jul 4th, 06, 09:38 AM
Mike68RS Mike68RS is offline
Mike
I have successfully removed it using the SmitfraudFix . Just make sure to run it in Safe Mode after you download it.
Mike
68 Camaro RS
Old Jul 4th, 06, 11:54 AM
click's Avatar
Moderator .. Jim
Jim
Guess this is part of it. That site thats holding my home page throws this alert up after each reboot. It shows this item present and to 'buy' their tool to remove it which I WONT.
W32.myzor.FK@yf
seems to be the virus but now I need to try that for fix that you guys suggested. Thanks.
Our Camaro Webpage
Photos for viewing
Old Jul 4th, 06, 01:49 PM
69camarofast 69camarofast is offline
Chris
Jim, i ran into the same kind of problem as far as my computer having its own mind...i also have Norton" and i ended up buying there tool and it didn't work, so i went through a 2 hr. Tec. phone deal with Norton and we found the problem..i think there Tec. people are based in India...because it was hard just to get someone to understand me..but then again (RamAirDave) tought me how to copy/paste.. ..
Muscle cars were loud, proud, and in your face, and did not pretend to be anything else.
Old Jul 4th, 06, 01:51 PM
Steptoe Steptoe is offline
Steps
There are 2 progs to manually remove hyjacks.
HijackThis
and
CWShredder
Google for them
Run the latter 1st.
Some of the hyjack sites are hard to remove, the write into reg files.
If CWShredder doesnt remove, run HijackThis
It gives u a list. a lot of the list u will be able to idenfiy as part of windows....and progs like acrobat reader update etc.
note the paths to files of the browser hyjack.
these will be
C:\
C:\Program Files\
C:\WINDOWS\
C:\WINDOWS\system32
Delete these items in hyjack this. reboot.
If the browser is still hyjacked..some hyjack are more sophisatcated and will reinstall on reboot.
Boot into safe mode (f8 as booting up)
Run hyjack this again
note paths to files...delete these files
run regedit (start /run)
run a search in regedit for the names of files and the name of the hyjacker
remove these entiies.
Check your favorites, delete the hyjack entries there.
Manually reset your home page ...IE/tools/internet options/general/homepage
(this can also be set in the hyjack this options.)
Reboot.
If the browser is still hyjacked, do the above again and check/edit c:\AUTOEXEC.BAT and any new /strange files in there
C:\Documents and Settings\each user name\Local Settings\Temp delete all files
C:\Documents and Settings\each user name\Local Settings\Temp\Temporary Internet Files delete all files
NOTE: If u are not familar with windows files. regedit etc, and u edit/delete something u shouldnt have u can end up with a even bigger mess.
If not sure on a file...run a google search for info.
To prevent further instances of browser hyjacking, dont go to underground sites and keep windows updated...at least every 2nd tue of the month.
Get rid of Symantic, and run KAV
install windows defender and keep updated
keep the firewall on
Old Jul 4th, 06, 02:05 PM
Black69 Black69 is offline
Dave
I got the same several months ago. It was a bugger to get rid of. I looked it up on Majorgeeks.com and used the smitrem and fixquake to remove it. Worked good since then. Just make sure you use a good program to remove it. Good Luck.
Dave, 69 Coupe, 383, Q-jet, Thorley headers, 350 turbo, P.S., P.B. console gauges, Tilt wheel, Black with green pearl paint, Black and White Houndstooth interior.
Old Jul 6th, 06, 05:47 AM
blackvi blackvi is offline
Jerry
Click,
Is the Virus Gone? A little tip I perform is to never operate my system under an ADMINISTER account. It really opens the door to Internet critters like you describe. If you have Windows Server Try demoting your account to a POWER USER and using the Administrator logon for system and software upgrades and rutine maintenance.
Old Jul 6th, 06, 10:00 PM
South Side Goons & Hitmen South Side Goons & Hitmen is offline
Gold Member
In my humble opinion go to your nearest Best Buy or Circuit City. Purchase Webroot Spysweeper. You may have to sweep your computer three times in regular mode and possibly three times when it is in safe mode. It's maybe $19.99 or $29.99 to purchase so it is not that expensive. Notorn is good for catching viruses but spyware is a whole other story.
Whatever you do, do not buy anything from the website that pops up and says click here to remove this virus. It is a ploy. These outfits will install more spyware on your computer and if your buy it online there goes your credit card number. Go buy Webroot Spy Sweeper. The purchase price includes a 1 year subscription that automatically updates the spyware defenitions. I use it on my computer and I love it. A friend of mine and his wife both had their computers infected. The webroot spysweeper removed all the threats.
Good Luck!!
Old Jul 6th, 06, 10:52 PM
click's Avatar
Moderator .. Jim
Jim
I already have webroot spysweeper I bought a year ago. It keeps finding pieces of this crud. But thats in my home PC, its unplugged now while Im in Billings. I will work on that upon return, thanks for the hints guys.
Our Camaro Webpage
Photos for viewing
Old Jul 6th, 06, 10:54 PM
Gary L's Avatar
Gary L Gary L is offline
Gold Member
"Tri-Tip"
I have that problem right now. McAffe did not detect anyhting. Another big help from this site!
Gary, SIM TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
http://www.camaros.net/showroom/data/500/DSC00005.JPG
http://www.camaros.net/forums/image....3&type=profile
http://www.camaros.net/showroom/show...0&ppuser=11189
Old Jul 6th, 06, 11:19 PM
Gary L's Avatar
Gold Member
"Tri-Tip"
I just ran Smitfraudfix. Thanks Dennis. Worked like a charm!
edit:didn't work after all. I will have to try something else.
Old Jul 7th, 06, 05:32 AM
Wayne Wayne is offline
Well I see I am not the only one, I do not know if it was the same but I got it yesterday when I was looking at this web site. I called the guy that built my computer and he came over and after about 2 hrs or so it is no longer showing up on the computer what he did I do not know but other than say that will be $65.00.
Wayne
Similar Threads
Virus By Hand Everett#2390 Bench Racing 3 May 25th, 06 07:22 PM
Check your computer for these virus nikkisdad Bug Hunt 1 Apr 11th, 06 12:11 AM
Virus alert.... DOUG G Bug Hunt 5 Mar 7th, 05 02:55 PM
Another Type of Virus Alert Scam twobytwo Bug Hunt 0 Mar 8th, 04 02:40 PM
VIRUS ALERT Indy 69 Tech 2001 9 Nov 29th, 01 06:52 PM
