Turbo 350 kickdown bracket - Team Camaro Tech
Old Jul 7th, 06, 06:21 PM
MickyT MickyT is offline
Lorne
Default Turbo 350 kickdown bracket
I have a Performer RPM intake manifold, Holley 670 Avenger carb and a stock kickdown bracket that mounts to the back 2 bolts on the manifold. When pulling the cable forward all the way after releasing the lock it stil seems to be about 1 1/4" too short. Is anyone using a different type of bracket or modifying the stock one to reach the carb pivot? Thanks
Old Jul 7th, 06, 06:48 PM
BPOS BPOS is offline
Al
Default Re: Turbo 350 kickdown bracket
You might have the wrong cable - I believe there are several different ones.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Jul 7th, 06, 09:08 PM
Lorne
You may be right. This one was in a box with a bunch of odds and ends. Hopefully someone will respond with the length they have that is working on the same type of setup.
Old Jul 7th, 06, 11:21 PM
Steptoe Steptoe is offline
Steps
I have a performer, with stock bracket, stock cable...had to bend the bottom bracket mounting tabs slightly, other that that its fine.
Old Jul 8th, 06, 01:27 AM
Lorne
Hey Steptoe could you measure the length of your cable from the bracket to the end of the slot. Mine is too short even when the cable is pulled tight and the housing is pulled forward through the bracket as far as it will go. Maybe its for some other application.
Old Jul 8th, 06, 01:44 PM
Steps
Not sure where u mean ..... the slot where it attaches to the carb?
Got the camaro stored down at the workshop at the moment, will look Mid monday morning.
Similar Threads
turbo 350 build questions 69rsinms Transmission & Driveline 7 Apr 6th, 06 12:14 AM
Turbo 350 won't stop leaking from rear seal! Guambomb Transmission & Driveline 2 Nov 22nd, 05 08:45 AM
4.11 gear to big? With Turbo 350 combo PERKS67-396 Performance 9 Aug 21st, 05 03:08 AM
396-325HP Th-400 kickdown switch bracket bigblockkid Tech 2000 3 Nov 25th, 00 11:16 AM
