Flywheel, Clutch, Pressure Plate Ques. ('68 396 w/Muncie_ - Team Camaro Tech
Old Jul 10th, 06, 10:09 AM
KevinK7 KevinK7 is offline
Kevin
Default Flywheel, Clutch, Pressure Plate Ques. ('68 396 w/Muncie_
...question on (factory original) flywheel, clutch and pressure plate for a '68 (Camaro) 396 w/Muncie trans.
Am I correct?, ...for the Big Block application, this would be the 14" flywheel (168 teeth) and an 11" clutch/press. plate?
(...and I do have the '621' bellhousing...)
Also, ...does anyone have any recommendations for for a clutch kit? (ie. brand, source, etc.) This is going in a show car that will be casually driven not raced...
Thanks,
Kevin
Old Jul 10th, 06, 01:39 PM
Straight-line-69 Straight-line-69 is offline
Default Re: Flywheel, Clutch, Pressure Plate Ques. ('68 396 w/Muncie_
You are correct on the parts. Also, you'll need the correct starter and flywheel cover for the 621 bellhousing.
If the car isn't a daily driver, use the Centerforce Dual Friction set up. If you drive her a lot, you might go with the Centerforce II. It's said the DF is a bit harder on flywheels but has 90% more holding power than stock. The II has 60% more holding power than stock.
But either has a light clutch pedal which is easy on clutch linkage and your lower body.
I use CF in four of my cars,..highly recommend it.
Old Jul 10th, 06, 03:04 PM
Bgonz 69 Bgonz 69 is offline
Bob
Centerforce is a real good clutch but a bit pricey,and you probably dont need the performance it will offer, i've been using a street clutch by ZOOM . SUMMIT and JEGS sells them for a little over $100 for everything. used 3 of them so far with no problems,real smooth and they grip great. I put one in my 81 Z/28 with a nice little 350 and tremec 5 speed and beat it to death.....no problems. ZOOM offers 3 varietys. Stick with the street clutch,you'll love it.
Old Jul 11th, 06, 04:40 AM
Kevin
...Thanks for the input guys
Similar Threads
Clutch and pressure plate. 69Z28 Engine 4 Apr 29th, 04 02:50 PM
calling chicane... pressure plate questions jks67SS396 Transmission & Driveline 4 Oct 26th, 03 06:41 PM
Help needed with Hays Clutch and Pressure Plate 69SSBIGBLOCK Troubleshooting 3 May 29th, 02 01:35 PM
flywheel and pressure plate balancing 68 redcam Engine 5 May 13th, 02 08:49 AM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 02:08 PM
