750 CFM too much for a 350 engine - Team Camaro Tech
Thread Tools Display Modes
Old Jul 14th, 06, 07:37 PM
Charles Brown Charles Brown is offline
Tech Team
Default 750 CFM too much for a 350 engine
I have a Edelbrock 1407 750 CFM ( Weber ) carburetor on a 350 CI engine with a mild cam. Is this the right carb for this engine? If so, what would you recommend? There are two screws on the front of the carb. Can somebody tell me how to adjust? Thanks.
Old Jul 14th, 06, 08:23 PM
buenymayor buenymayor is offline
Default Re: 750 CFM too much for a 350 engine
750CFM sounds too big for a mild cam. IMHO, 600- 650CFM would be a better choice.
Old Jul 14th, 06, 08:32 PM
mnm99's Avatar
mnm99 mnm99 is offline
Marc
I'm running a holley 600 Vac sec on a comp 280H, 10.1:1 350. Runs great!
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
Old Jul 14th, 06, 09:51 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
I removed the Holley 750 and edelbrock that was on mine when I bought it and went with Qjet 650 and cast iron manifold.. runs great and MUCH better mileage compared to the Holley, it was way to much.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Old Jul 14th, 06, 11:22 PM
HarleyD67's Avatar
HarleyD67 HarleyD67 is offline
Harley D
For a 350 to need a 750cfm carb it needs to be built to the hilt and designed to spin way past 6k. With your set up you would be much happier with a 600 vac. secondary carb. It will give you better throttle response better drivability and better fuel economy. Not to mention easier to tune.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.7281/4-11.83@115.59
firstgens.com
Old Jul 15th, 06, 02:48 AM
1stgenCR 1stgenCR is offline
yup as others have said 750 is overkill unless you got some nice flowing heads big cam and high compression
BTW holley has an online questionaire on their site now that will give you an approximate CFM for your engine.
Old Jul 15th, 06, 10:48 AM
Tech Team
I think I will drop down to the Edlebrock 600. My 750 is mounted on a high intake plate. What is the advantage to this vs mounting it straight to the intake itself?
Old Jul 15th, 06, 10:52 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
So, for decades, all the engines built by GM with Q-jets on them were all way over-carbed?
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Jul 15th, 06, 01:32 PM
wildman926 wildman926 is offline
Walter
The quadrajet has the tiny primaries, but the secondary top flap is opened via vacuum, so depening on the tuning whether or not they opened all the way or not.
Old Jul 15th, 06, 02:17 PM
TJS69 TJS69 is offline
Tom
G.M. had it right with those small primaries. I tried a 750 on my 327, way to big. Even the 600 I use now still has too large of primaries for my liking. I'd switch back to a Quuadrajet, but I'd have to get a new intake also, or use an adapter. Fuel Injection ? Maybe.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
  #11
Old Jul 15th, 06, 02:27 PM
onovakind67 onovakind67 is offline
Use an adapter, they work just fine.
  #12
Old Jul 15th, 06, 02:41 PM
DOUG G DOUG G is offline
If the 750 was a vs carb it should be fine... but a smaller carb would increase throttle responce.
68 Camaro~LSx
Best to Date....and tuning
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.
RedЯum <-Pics
https://youtu.be/Of8WVNYhR1g <~More here
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: 750 CFM too much for a 350 engine
Location
Location
First Name
Human Verification
Similar Threads
I Need Pictures of A/C compressor mounted. 350 engine POCKER Heating & Cooling 5 May 31st, 06 05:22 AM
I Need Pictures of A/C compressor mounted. 350 engine POCKER Heating & Cooling 2 May 27th, 06 08:32 AM
67 RS/SS 350 Need help with Engine Compartment cjmace Engine 1 Jan 31st, 06 04:24 AM
Engine swap 305tbi to 350 carb hilliusracing31 Engine 1 Jan 28th, 06 02:20 PM
Timing of 350 engine GreyShadows Performance 12 Apr 19th, 04 12:24 PM
