HELP TH400 tailshaft question?..pics included - Team Camaro Tech
Thread Tools Display Modes
Old Aug 1st, 06, 10:45 PM
darthvegagt darthvegagt is offline
Tech Team
Default HELP TH400 tailshaft question?..pics included
I have a TH400 like the one in the link that has a fixed yoke rather than a slip yoke. I got this transmission with a 454 as a package deal for my 69 camaro. I know that I need to change the tailshaft and output shaft in the trans but does that involve tearing down the whole trans? Or can this be coverted to a slip yoke with minor work? The trans has a lot of work done to it and I would definately like to adapt it with the least work. Can this be done easily or will it be more hassel and money then what its worth? Should I start looking for another trans.? Any ideas or help would be great. Thanks Jordan
http://cgi.ebay.com/ebaymotors/CHEVY...QQcmdZViewItem
1969 Camaro 454/TH400, 4 wheel power disc brake conversion w/ drilled and slotted rotors. Coys wheels 18x8 front and 20x8.5 rear. Pro touring project in the making....
Old Aug 1st, 06, 11:08 PM
jakeshoe jakeshoe is offline
Jake
Default Re: HELP TH400 tailshaft question?..pics included
You can use a special yoke for the truck output shaft, it is counterbored. Most driveshaft shops should know what you need.
www.jakesperformance.com - High performance GM automatics/LSx Engines and Parts.
Old Aug 1st, 06, 11:13 PM
Tech Team
Really? The truck has a 2 piece driveshaft. I will try to call a driveshaft shop this week.
Old Aug 1st, 06, 11:15 PM
Tech Team
how does that yoke work in place of a slipyoke style? thanks
Old Aug 2nd, 06, 12:36 AM
Jake
It is a slip style yoke, instead of being mounted to the output shaft, it will slip on the output shaft splines but it must be counterbored to fit the threaded output shaft.
The Th400 output shafts used in trucks with a bolt on yoke have an o-ring and a raised portion just ahead of the splined portion, this will cause a regular passenge car yoke to bottom out on the raised ring portion.
The "conversion" yoke is counterbored to fit over this raised portion, and still have enough spline engagement and travel.
http://www.chevelles.com/forums/show...put+shaft+yoke
Old Aug 2nd, 06, 08:11 AM
Tech Team
thanks man, sounds like you have dealt with this before. I appreciate your help, do you know where I can find one, or do you have a link to one so that I can see it and buy one? Also by using this yoke, will it still be just as good as using a passenger car TH400 or are there any drawbacks?? thanks man. Jordan
Old Aug 2nd, 06, 04:34 PM
Jake
Denny's Driveshaft can hook you up, www.dennysdriveshaft.com.
I believe Tom's Differentials also carries them.
Most driveshaft shops should be able to get them.
No real drawback, they work fine.
I am doing a Th400 right now going into a Chevelle that is using this yoke.
Old Aug 2nd, 06, 04:37 PM
Jake
http://www.dennysdriveshaft.com/html/slip_yokes.html
T-400 & 4L80 For Use on THREADED OUTPUT 32 Spline
Slip yoke is specifically designed to be used on a T-400 & 4L80 with the Threaded Output shaft. This design will replace the truck style bolt on yoke with a car style slip yoke and allow for proper slip travel and bushing contact for best performance. A must for any threaded output shaft on T-400 & 4L80 transmissions. We designed this yoke to solve this problem over 25 years ago.
Old Mar 11th, 09, 07:03 PM
69 z11 69 z11 is offline
Jerry
OK, so I can get a TH400 out of 4WD truck for $100. It has a really short tailshaft, and appears to have the bolt on yoke. Is it worth the hassle to get this cheap, or should I keep looking around for a "correct" TH400? Opinions?
69 Z11 03D Van Nuys
82 Z28 Gordon Johncock's Pace Car
97 30th Z28 6 speed vert 1 of 175
A Pair of Huggers at the Car Show
Old Mar 11th, 09, 07:19 PM
hereitis67 hereitis67 is offline
bill
no you cant get a 4x4 tranny. you need 1 out of a 2wd vehicle.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: HELP TH400 tailshaft question?..pics included
Location
Location
First Name
Human Verification
Similar Threads
TH400 question and pics. chevyoldman Tag Team 3 Apr 4th, 02 09:03 AM
TH400 Mounting Question ChevyCam Engine 2 Aug 5th, 01 07:12 AM
New guy here with TH400 question SSMOKEM Engine 8 Mar 10th, 01 04:04 PM
TH400 Driveshaft question 67rag Engine 3 Jan 14th, 01 03:38 PM
TH400 cross member question 67rag Engine 4 Jan 14th, 01 03:35 PM
