Timing Cover Seal ? - Team Camaro Tech
Old Aug 3rd, 06, 01:38 PM
rojo rojo is offline
Robert
Default Timing Cover Seal ?
I have a 8" balancer with a groove cut in it from the seal. Or at least I think that's how it got there. Is there a offset seal made so that the lip is relocated a bit.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
'77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25
TC member #18
Old Aug 3rd, 06, 03:25 PM
ZZ430DropTop67RS's Avatar
ZZ430DropTop67RS ZZ430DropTop67RS is offline
Don
Default Re: Timing Cover Seal ?
They make a sleeve that goes over the damaged part, available at all parts places.
Don ~ TC Member #15 ~ http://www.flickr.com/photos/46701464@N06/
Old Aug 3rd, 06, 04:29 PM
Robert
Don,
Thanks for turning on the light switch. I actually have another 6.75 that has the sleeve and didn't realize why it was there. I was thinking the solution would be more like an offset axle bearing seal. I'll pick up a sleeve.
Robert
TC member #18
Old Aug 3rd, 06, 05:41 PM
Everett#2390's Avatar
<Jake 68's Rule
Make sure the seal sleeve goes on straight and use the whole tube of sealant between the sleeve and h/bal.
You can use a place on the smooth concrete floor for the face of the balancer and a block of wood squarely on top of the sleeve. Make a direct straight/square blow with a BFH to install. Of course, a 12-ton press will do nicely.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Aug 3rd, 06, 05:49 PM
zdld17 zdld17 is offline
Don
And when you put it all together,, wipe a little glob of RTV on the key way slot on the balancer to seal out any oil that may want to leak thru the keyway... Use a good 6 point hardened crankshaft bolt and washer to lock it all down...Arp and Mr Gasket make a nice set, Loctite on the bolt threads.
Save your rear main bearing thrust surface,, use the proper harmonic balancer installer, not the 10# ford tool .
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Aug 4th, 06, 05:06 AM
Robert
Thanks for the install tips. I have a shop press and a balancer installation tool so hopefully it will go well.
Robert
TC member #18
Old Aug 4th, 06, 05:11 AM
Don
You can use a shop but you can also tap the sleeve on (with a little rtv inside it) with a little block of wood and a 5# ford tool. Just make sure you go straight. Watch closely and you will see the sleeve swell some. You are done.
Don
TC # 349
Similar Threads
total timing blue67 Performance 12 Sep 10th, 06 10:27 AM
new cloys timing cover wont allow 8" balancer, looking at a TCI MY FIRST 69 Engine 0 Jun 22nd, 06 04:01 PM
Mismatched timing cover and balancer travis Engine 7 Apr 22nd, 04 08:25 AM
Timing Cover AJL69 Engine 2 Oct 1st, 03 04:34 PM
Comp Cams 2-Piece Timing Cover cmrib Engine 5 Jun 23rd, 00 06:08 PM
