Volt meter... not accurate? - Team Camaro Tech
Old Aug 7th, 06, 11:21 AM
maxharvard maxharvard is offline
Default Volt meter... not accurate?
With all the accessories on and car running, i've tested the alternator and battery with a multimeter.
At the battery i get a reading of 14.20
At the alternator i get 14.22
However, the gauge in the dash says 12.8-13.00. I've checked all my grounds and everything seems to be grounded well.
Ideas? Suggestions?
http://www.anti-rice.com <TR>
My '68 Camaro
Old Aug 7th, 06, 12:02 PM
Mister G Mister G is offline
Default Re: Volt meter... not accurate?
Where does your dash mounted gauge measure the voltage? If it is not right at the battery you probably have some voltage drops due to resistance. Not knowing what type of DMM you are using i would still venture to say that unit is more accurate than a dash mount.
CamaroRS
Old Aug 7th, 06, 12:10 PM
JimM JimM is offline
Jim
the best check would be to use yuor meter, and check the voltage at the guage. #'s agree, you have a voltage drop in the wiring, troublesome but not a huge problem yet if everything works right. #'s don't agree, car is good, guage is off. Again, not a huge problem.
Old Aug 7th, 06, 02:10 PM
True... the gauge is wiring directly into the harness... Everything does work well. I guess its a minor annoyance to have a gauge that doesnt work properly.
It just bothers me that i have a gas gauge issue as well, both are buggin the hell out of me.
My '68 Camaro
Old Aug 8th, 06, 04:04 AM
undee72Z undee72Z is offline
Ideas? Suggestions?
Temp wire the gauge right to the battery, if its still low the gauge is off, if same readings as multimeter, either voltage drop or poor connections somewhere. How much difference in voltage if some or all of the accessories are turned off? Try cleaning the connections at the horn relay buss bar,
Greg U
My 72 Z
Undees 70 SS, street driven drag car
Old Aug 8th, 06, 08:46 AM
Everett#2390's Avatar
<Jake 68's Rule
I have noticed on alot of GM cars & trucks through the years, e.g., 88 Monte Carlo SS & 88 Chev C3500, GM in-dash voltmeter reads mid-scale, as designed.
MCSS reads 13 volts midscale. Chev reads 14 volts midscale. Both read 14.5 volts at battery & alternator. So, it could be the gauge scaling. If you ever get to the voltmeter source or voltmeter itself, this will tell the story.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Similar Threads
Measuring Electricity JimM Electrical & Wiring 7 Mar 3rd, 06 09:29 PM
120 volt to 12 volt power supply sneakey pete Bench Racing 6 Mar 1st, 06 01:14 PM
Is It An Amp Gauge Or A Volt Meter? 69-er Electrical & Wiring 17 Jan 1st, 06 02:16 PM
Amp meter location orange 68 Engine 6 Apr 26th, 05 03:50 PM
volt meter chuckboy7 Electrical & Wiring 3 May 30th, 04 03:46 PM
