painting fiberglass - Team Camaro Tech
Body Shop Paint & Body Forum
Old Jul 27th, 03, 06:34 AM
emtcee1973 emtcee1973 is offline
Post
do i need special paint to do my fiberglass parts(spoiler and hood)or can i just use the same process as the rest of the car?
Picts
Old Jul 27th, 03, 10:30 AM
69lemans 69lemans is offline
Post
Use the same process.
jamie
Old Jul 27th, 03, 03:43 PM
NHRA1877 NHRA1877 is offline
Post
We did a friends fiberglass front end and a few other pieces, he had the paint store mix in a Flex additive to keep it from crackin...
68 Camaro - 10.42 @ 129 1.46 60`
NJ Bracket Racer http://community.webshots.com/user/nhra18772 If it wasn`t for my dad, I would know nothing, thanks for everything Dad
Old Jul 27th, 03, 03:54 PM
BBCamaro BBCamaro is offline
Post
no you do not need anything special, some flex additive is good like nhra said, but to be effective you should use it from the primers up, put some in each step of paint, some in the 2k primer/ then some in the sealer then in the base then in the clear or if you use single stage then just in the primer/sealer/arylic enamel.
bull dog makes a good adhesion promotor/flex agent that come ins quarts for cheap money like 15 bucks a quart and 1 quart would do a car you only need a little bit in each step, like a 5-10% into your primer or paint mix.
also on fiberglass be carefull when using a da sander as its easy to make craters,when trying to feather out a chip, if its chiped your better off sanding easy but enough to rough it up and apply a light coat or finishing glaze or some bondo then feather it out, goodluck
jake
1968 Camaro streetfighter, 18x10,18x12 ccw's,tq arm rear,apex c6 front sub,ls6 asa cammed dry sump,t-56,335/30/18 and 275/35/18 toyo r888
www.jakesrodshop.com
Jake's Rod Shop
207-595-0677
