One Wire Alternator problem - Team Camaro Tech
Old Aug 10th, 06, 07:10 PM
freebird freebird is offline
Default One Wire Alternator problem
Hi All, got all my wiring and starter problems squared away with help from the board...I am in the home stretch. Just got a new one wire summit alternator.
Hooked it up...One wire (4 Guage) from the post on the alternator to the battery side of my kill switch in the trunk.. Anyway it wont charge..Had it tested twice and they say its good. Anyway I had my buddy rev the motor and I put a volt meter on the alternator post and ground and it read 12 volts..not charging. It tested the wire and the connections are good..
If the alternator is no good is that a common thing for a new one to be junk?
Any Ideas??
thanks
Chris
Old Aug 10th, 06, 08:10 PM
Eric Kammerer Eric Kammerer is offline
Default Re: One Wire Alternator problem
How high did you rev it? A lot of one-wire alts have to be run up to start charging.
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Aug 10th, 06, 08:59 PM
HarleyD67's Avatar
HarleyD67 HarleyD67 is offline
Harley D
In most cases 2000-2500 is usually enough to excite it. Mine excites after it's taken over 1000 and continues to charge even at idle @850.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.7281/4-11.83@115.59
firstgens.com
Old Aug 11th, 06, 09:06 AM
dnult dnult is offline
Are you sure it's not a 3 wire (a.k.a. 5 wire) alternator such as a CS130? They can be wired as a 1 wire alternator, but the brown lead (that typically is connected to the GEN lamp) needs voltage applied to it to excite the alternator. If you don't use a lamp, you can connect the brown wire to the B+ lead, but you need a resistor in series with it to limit the current. If it is in fact a 1 wire alternator, then disregard.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Similar Threads
1 Wire - 3 Wire Alternator Question redlines4us Electrical & Wiring 8 Jun 26th, 07 01:16 PM
1969 Camaro Firewall Wire Harmess Phillip_L Electrical & Wiring 3 Jan 23rd, 06 06:10 PM
PO 300 301 302 OBD II 3L 4P Bench Racing 9 May 6th, 05 07:02 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 01:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 01:57 PM
