Cam Help Voodoo 60103 or 60104 - Team Camaro Tech
Thread Tools Display Modes
Old Aug 16th, 06, 11:02 AM
Spirit1 Spirit1 is offline
Tech Team
Default Cam Help Voodoo 60103 or 60104
Need cam help I need to choose between these two cams or other cam? My car is a 69 camaro TKO 500 5spd 12-bolt 3:73 gears I have stock power disc breaks and factory air-conditioning. I am building a new 406 spec's are:
10.5 speedpro pistons
5.7 Scat rods
Balance bottom end
Edelbrock 200cc V-tec heads
Harland sharp 1.5 roller rocker
1 3/4 headers
2 1/2 magna flow complete exhaust system with x pipe
Cam Voodoo 60103 or Voodoo 60104
I mainly street/show drive the car with 4 trips to the drag strip a year. I also want the car to have a nice choppy idle.
Any advice on this engine combo would be appreciated
Old Aug 16th, 06, 01:20 PM
rojo rojo is offline
Robert
Default Re: Cam Help Voodoo 60103 or 60104
This might help the discussion some.
60103
Advertised Duration IN/EX: 268/276
Duration @ .050 IN/EX: 227/233
Gross Valve Lift IN/EX: .489"/.504"
LSA / ICL: 110/106
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 1800-6200
60104
Advertised Duration IN/EX: 276/284
Duration @ .050 IN/EX: 233/241
Gross Valve Lift IN/EX: .504"/.525"
LSA / ICL: 110/106
RPM Range: 2200-6400
60105
Advertised Duration IN/EX: 284/292
Duration @ .050 IN/EX: 241/249
Gross Valve Lift IN/EX: .525"/.546"
LSA / ICL: 110/106
RPM Range: 2500-6600
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...T56 Magnum, 3.73 Moser 12 bolt
TC member #18
Old Aug 16th, 06, 02:39 PM
AH32 AH32 is offline
I vote for the 60104, but maybe on 108 LSA.
Old Aug 16th, 06, 07:19 PM
Robert
This could do better in the Performance forum if it could get moved. I'm interested in comments on the 60104.
Robert
TC member #18
Old Aug 17th, 06, 07:43 AM
Dave69Z Dave69Z is offline
I vote for the 104 in your 406. I run the 103 in my 350/330ho motor and its barely noticeable. It puplls 13 inches of vacum at 750 rpm idle and pulls strong all the way to redline.
Old Aug 17th, 06, 08:56 AM
Tech Team
Thanks for the info. That is what i was looking for. Plus i was also wanting to know what vacum my motor would pull. I am leaning towards the 104. I also need to check into clearance issues with std base circle cam to connecting rods on a 400.
Old Aug 17th, 06, 09:49 AM
wildman926 wildman926 is offline
Walter
What is your redline?
Old Aug 17th, 06, 11:27 AM
Tech Team
I am building everything to work from 2,500-6,200 range. I am using a edelbrock airgap intake and a holly 750 dp.
Old Aug 17th, 06, 02:12 PM
pdq67 pdq67 is offline
Banned
Thumbs up Re: Cam Help Voodoo 60103 or 60104
Please consider a good old Isky Z-25 or Z-27 solid lifter cam, imho!
pdq67
PS., but then again, I'm a solid lifter cam kinda guy!
Old Aug 17th, 06, 03:54 PM
Big Willyz Big Willyz is offline
Tech Team
I am in the 406 build process as we speak... I went with the Voodoo 60103 on a 108 LSA small circle based. After discussing the build with tech at Lunati, that is what they reccommended. My car is also a driver that will see minimal strip time. I didnt want to go too far with my selection. On the desktop dyno.. it pulled 477 HP and 490 FT/Lbs... which is pretty bitchin for a driver. Let me know how the 104 works for you... would love to know what I coulda went with...lol
  #11
Old Aug 17th, 06, 05:13 PM
HarleyD67's Avatar
HarleyD67 HarleyD67 is offline
Harley D
I would say for what you want the 104 is a better choice. Although the 103 is very good as well. I have the 60105 in my 427 small block. It was a real torque monster, and pulled great to @5800 with my Stealth. Now with my Team-G 7532 it still has gobs of torque , but really pulls from 4000-6300. I pulled 11-12" vac. with the Stealth, and a solid 10" with the Team-G.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.7281/4-11.83@115.59
firstgens.com
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Cam Help Voodoo 60103 or 60104
Location
Location
First Name
Human Verification
Similar Threads
Cam comparisons zdld17 Performance 8 Aug 9th, 06 12:29 PM
327 Cam and parts redo ???? bdcole_51 Performance 11 Nov 4th, 05 08:03 PM
New formula - cam suggestions... long! blackvi Performance 10 Oct 17th, 05 05:38 PM
Choosing a cam via DD2k iterative testing......... Granny's 69 Performance 4 May 25th, 04 11:30 AM
274xe vs. hot cam on vortecs czar Performance 20 Jul 16th, 02 12:01 PM
