Block Casting date questions - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Aug 20th, 06, 12:42 PM
peter19ue peter19ue is offline
Default Block Casting date questions
Hi:
Are there any other areas besides the machined pad on the engine block that contain the partial vin and engine code that determine when the block was made or what year or car the block is out of? I am looking at a car and the owner claims the engine is out of a 69 camaro but he is not sure if the partial vin or engine code are restams or not. Where else can I look. Is the another area where the block has casting #'s to determine if the motor is date correct
Thanks,
Old Aug 20th, 06, 07:14 PM
JohnZ JohnZ is offline
Team Member
John
Default Re: Block Casting date questions
The block casting number is on the driver's side of the block, behind the cylinder head, on the flange where the bellhousing bolts up; the block casting date is on the other side, about six inches outboard of the distributor.
JohnZ
CRG
'69 Z/28 Fathom Green
Old Aug 20th, 06, 08:47 PM
Thanks John:
From these #'s will I be able to tell what year the motor was manufactured and what type of car it was originally in?
Thx, Pete
Old Aug 20th, 06, 09:15 PM
firstgenaddict firstgenaddict is offline
James
The only way to tell the true application is to know what the stamped suffix is. Nothing else will give you 100%. The casting number and date can eliminate alot of possibilities and the vin could get you closer but other than that...
If they do not know if it is restamped get a photo and there are alot of guys here who can at worst say whether it deserves another look.
James
"Collectin' Camaro's since only Rednecks Drove them"
https://picasaweb.google.com/1123922...28_Restoration
Old Aug 21st, 06, 04:44 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Mike
Some casting numbers were only made during specific time frames, so it may be possible to tell what year block you have.
Team Camaro Gold Member #14
1967 Camaro RS/z28 - one of 602 made - SOLD
1969 Camaro RS/SS L48 4 speed
1974 Camaro LT-Z/28 4 speed 33K orig miles
1979 Camaro Z/28 36K orig miles
1984 Camaro z/28 LG4 auto
Similar Threads
casting and date code question help please larson305 Tag Team 5 Feb 1st, 06 12:15 PM
Casting Dates Heads Vs Block DZ Fool Tag Team 9 Oct 22nd, 05 04:39 PM
Engine Block Casting Date DBUCHH Tag Team 1 Nov 17th, 03 09:05 AM
Does this casting date match? 396rs/ss Tag Team 3 Jun 6th, 02 04:23 PM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 02:08 PM
