Time between base coat and clear coat - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Sep 5th, 06, 04:08 PM
Bob O Bob O is offline
Tech Team
Default Time between base coat and clear coat
I've read several articles on base coat/clear coat painting but have not seen this addressed. Maybe it isn't pertinent but I would like to make sure. I'm ready to spray my '67 and would like to know if there is a minimum or maximum time to wait after spraying the base coat before applying the clear coat? Is the clear applied as soon as the base dries, should you wait 'til the next day, what's the best way to proceed? Thanks.
Old Sep 5th, 06, 04:21 PM
tired68 tired68 is offline
Default Re: Time between base coat and clear coat
You need to read the P-sheet for the brand of paint you plan to use. For instance, PPG's DBC/DBI product specifies a time between coats of 5-10 minutes and a "Dry Time to Clearcoat" of 15 minuts at 70F with a maximum of 24 hours.
If you miss the 24 hour window for getting your clear coat sprayed out, you'll need to scuff the base to specs, spray another coat of base and then clear within the 24 hour window.
Other products have different recoat windows. Learn your way around the product sheets for the paint you've chosen before starting the job. Most paint vendors have the product sheets online. If you can't find them, your paint jobber has them at the counter. Many paint failures are the result of incorrect product use and recoat window is an important spec. Missing the recoat window will reduce or prevent the chemical bond between layers and clear can peel off.
Old Sep 5th, 06, 04:25 PM
heavy_chevy29 heavy_chevy29 is offline
dan
it really depends on the manufacturer. it could be anywere from 10 to 30min. get a tech sheet for the base you are using. or call the palce you ordered it from. they should know. i usaully wait 10-15min between base and clear unless there is a problem. also, another factor to consider is the reducer that you are using. that will also help determine the flash time in between coats.
68 project car
84 z28 with scott shafiroff 434sbc (576hp-582 ft-lbs of torque)
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Time between base coat and clear coat
Location
Location
First Name
Human Verification
Similar Threads
"Basics of Basics" Plastic filler ("Bondo") MARTINSR Body Shop 10 Sep 18th, 06 09:26 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 02:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 02:57 PM
Welds complete and grinding; MartinSr. type question shelbydog Body Shop 13 Dec 6th, 02 06:04 PM
filler primers my68 Body Shop 36 Feb 27th, 02 07:21 PM
