?'s About My Set Up. - Team Camaro Tech
Old Sep 7th, 06, 12:10 AM
EZ's73 EZ's73 is offline
Default ?'s About My Set Up.
i RECENTLY PURCHASED A 73 CAMARO WITH A 383 W/
10.3 TO 1 COMPRESSION,COMP CAMS XE284H,RPM AIR-GAP MANIFOLD,1.5 ROLLER ROCKERS,PORTED & POLISHED 041 STOCK IRON HEADS,AND A 725 ROAD DEMON CARB.i ALSO HAVE A TH350 TRANNY W/A B&M TORKMASTER 3000 STALL.THE REAREND CONSIST OF A 10 BOLT W/NO POSI AND EITHER 273 OR 308 GEARS..CAN SOMEONE PLEASE TELL ME APPROX HOW MUCH HORSE POWER & TORQUE i HAVE.iALSO WANTED TO KNOW WILL THE 10 BOLT HOLD UP.THE CAR IS TO SEE MOSTLY STREET DRIVING & SOME STRIP DUTY.DOES ANYONE HAVE ANY SUGGESTIONS?MY GOAL IS LOW12'S TO HIGH 11'S.I ALSO HAVE PATRIOT 1 5/8 HEADERS WITH 2 1/2 INCH EXHAUST W/2 CHAMBER FLOWMASTERS.ANY HELP WOULD BE GREATLY APPRECIATED.
Old Sep 7th, 06, 10:18 AM
Vintage 68's Avatar
John
Angry Re: ?'s About My Set Up.
OMG - YOUR CAPS KEY IS STUCK
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Sep 7th, 06, 12:28 PM
travis travis is offline
Default Re: ?'s About My Set Up.
With a set of 3.42 to 3.73 gears, plus upgrading your torque convertor to at least a holeshot 3000 convertor, you should be in the mid-high 12's if you can get traction. The torkmaster series of convertors are not really made for that kind of output...I've broken them behind hopped up 305's in heavy cars! You should have a 8.5" 10 bolt in there...it is plenty strong.
"This is not a cheerocracy...I make the cheercisions around here"
Similar Threads
What part is adjusted to set caster? ray moore Brakes, Suspension & Steering 2 Jul 4th, 06 04:47 PM
Complete bushing set 67 Swedish Convertible Brakes, Suspension & Steering 5 Jun 24th, 06 05:08 PM
chev crate motor rockers running off set on valves Eugene Engine 7 Feb 17th, 06 09:34 PM
