worn valve guides...erratic vacuum? - Team Camaro Tech
Thread Tools Display Modes
Old Sep 8th, 06, 03:11 PM
jks67SS396 jks67SS396 is offline
Jeff
Default worn valve guides...erratic vacuum?
Can someone explain how worn valve guides would create an rapidly fluctuating vacuum signal on a vacuum gauge?
thanks
1967 SS 396, M20.
now a 10.4:1 540, AFR 315 heads, UDHarold SR Cam with a Tremec TKO
Old Sep 8th, 06, 08:15 PM
zdld17 zdld17 is offline
Don
Default Re: worn valve guides...erratic vacuum?
Worn guides will not let the valve head seat directly on the valve seat, thus causing a mismatch on the faces. Thus not sealing properly. Remember that the motor is basically an air pump.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Sep 8th, 06, 08:45 PM
Jeff
Thanks DoubleD!
1967 SS 396, M20.
Old Sep 8th, 06, 09:16 PM
sleeper69 sleeper69 is offline
Have you checked the compression on each cylinder?
Every time that I have observed a rapidly fluctuating gauge I have had a burned valve or bad seat. May not be the case here but worth a compression check. A broken valve spring will do the same thing.
Old Sep 9th, 06, 12:25 AM
Jeff
ive had th same symptoms for a year and i did do a compression check last year. all where 190-200 psi.
did a leak down test too...and that came back fine too. a vacuum leak or bad guides might still pass both tests, right?
is there a way to test the valve springs without taking everything apart?
thanks
1967 SS 396, M20.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: worn valve guides...erratic vacuum?
Location
Location
First Name
Human Verification
Similar Threads
Valve stem seal replacement question HwyStarJoe Engine 19 Aug 2nd, 05 10:40 AM
valve guides and seals jks67SS396 Engine 7 Jul 21st, 05 04:42 PM
68 vacuum headlights Opening but not closing AAAAGGGG!!! ray moore Electrical & Wiring 11 Jul 7th, 05 05:01 PM
Petronix Distributor Vacuum Advance Planet Camaro Engine 2 Apr 15th, 05 03:42 PM
HELP ME with adjustable vacuum advance 67stock Tech 2000 4 Feb 2nd, 01 10:05 PM
