Official Sponsor of Team Camaro |
| Team Camaro Tech Current Topic: 502 RJ Installed in 2nd Gen pics | ||
| Second Generation 1970-1981 |
Well, The engine is in place, and the intake is mounted. I had to take out 7/8 inch for the manifold to clear the steel cowl hood. Once the intake was welded up I had it powder coated silver. I still have to wire it up, install fans, and bolt up the battery. I'm hoping to start it up in a week or so. Here are some pics...
wow we will need a video of ya driving that bad boy soon
2 70 chevelle 1 70 elco 1 71 chevelle 2 71 elco 1 70 camaro 1 69 raysoncraft flatbottom looking for 70 12 bolt for camaro |
Very, very cool!
Do you have pics of the intake mods?
Don ~ TC Member #15 Gold |
DropTop The only pics I have are of the intake installed...similer to what is posted. I'd be more then willing to email them to you. Tom |
I'd like to see those Tom, we did a 70 El Camino with the same motor, thankfully the stock cowl hood was high enough. I'm thinking about the 502 RJ in a 72 Camaro.
Very nice!
Silver Bullet 1977 Z-28 *New 408 - no ET's yet. *413 Phase 6 heads Comp 306S Vic Jr 3310 Holley 11.73@115.10 on drag radials @ 3725 lbs. *Vortecs 234/244 Crane RPM intake 3310 Holley 12.15@110.52 @ 3760+ lbs |
Not sure whether I sent any pics or not so here they are...
http://i145.photobucket.com/albums/r...Picture065.jpg http://i145.photobucket.com/albums/r...Picture073.jpg http://i145.photobucket.com/albums/r...Picture040.jpg http://i145.photobucket.com/albums/r...Picture032.jpg |
Youll love the response of the ramjet, shocks the tires pretty hard! I have a 502 Merc Marine Ramjet in a 67 prostreet
NICE. What software are you running? How are you going to route the cold air intake?
JJarky, I'm running stock ecm/software. It runs great except that when I let off the excelerator RPM dips below idle then raises. Sounds like it's going to stall...then comes back to idle...
#11
nice can we see the rest of it
#12
Hi Tom! My ramjet 502 is about to go in the '69 project I just bought. But I was seriously considering swapping to a carb before I read your post. (I might still, but not just because of the height issue. The project is also missing the wiring harness, fuel pump, install guide, diagnostic tool, and proper fuel lines. And since it was built in 12/2001 I believe it is an MEFI3 controller which some have said is a little trouble-prone?)
Since the shop is about 45 minutes away... Do you remember any obstructions below that made you stop at 7/8" or was that just all that you needed? Also, since the issue is in the front would it make sense to trim the front a little more or would a small height difference disrupt the fuel/air delivery? I was thinking about painting my intake red to match the engine compartment anyway so cutting/welding/grinding shouldn't be a big deal. Thanks for sharing a great idea!! Jason |
#13
Nice job!
1972 Rally Nova. 496 bbc. Turbo 400 w/2.75 tci 1st gear. Moser 9" w/3.73, Detroit locker and alloy axles. |
#14
Similar Threads
| 2nd gen tag decode? | KevinK7 | Second Generation | 4 | Oct 16th, 06 04:20 PM |
| 1st gen & 2nd gen differential differences | Davisalmound | Transmission & Driveline | 4 | Aug 29th, 06 07:22 PM |
| need 2nd gen. interior | bone | Second Generation | 1 | Aug 25th, 06 07:40 AM |
| 69 LS1 Project Update.. Many parts installed.. pics | Steve2000SS | Bench Racing | 10 | Feb 22nd, 04 06:52 AM |
