Lt1 1970 Cam Specs ??? - Team Camaro Tech
Thread Tools Display Modes
Old Sep 11th, 06, 01:45 PM
ERHARD ERHARD is offline
Tech Team
Default Lt1 1970 Cam Specs ???
Does anybody know the cam specs for the 70 lt1 350 as compared to the 69 z28 30 30 cam.
THANKS
Old Sep 11th, 06, 02:06 PM
Gary L's Avatar
Gary L Gary L is offline
"Tri-Tip"
Default Re: Lt1 1970 Cam Specs ???
Per Zdld17:
Ok here are the specs for GM off road cams :
# 3927140 1st optional
Lift @0 lash Int .492, Ex .512
Valve timing:Intake
Open btc 53*
close abc 100*
Duration 333*
lash .022
Exh:
open @bbc 101*
closing @ atc 65*
duration overlap 346*
2nd optional # 3965754
Lift @0 lash
int .512
exh . 536
Valve timing Intake
open btc 49*
close abc 95*
duration 324* lash .022
overlap 105*
Exh:
open bbc @ 98*
close atc @ 56*
duration 334* lash .024
Forgot to add the newer Lt1 Cam 3972178
Lift @0 int .458, exh .485
Int valve timing
open btc 42* @ .040
clos abc 94* @ .020
duration 317*
lash .024
exh timing
open bbc @ 112* @ .050
close atc 53* @ .023
duration 346*
lash .030
The stock 302 cam 3849346
lift .485/.485
valve timing
int open btc 60*@ .040
close abc 105* @ .023
duration 346 @ .013
exh :
open bbc 108* @ .050
close atc 57* @ .023
duration 346 @ .030
lash 30/30
"Government is not reason; it is not eloquent; it is force. Like fire, it is a dangerous servant and a fearful master." ..... George Washington
Gary,TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Lt1 1970 Cam Specs ???
Location
Location
First Name
Human Verification
Similar Threads
69 302 cam specs stenn5 Tech 2000 17 Nov 14th, 13 04:41 PM
77 Chevy Truck 350 Cam and Head Specs bullitt07 Tag Team 2 Dec 7th, 03 05:02 AM
1970 LT-1 cam .459"/.485" .242*/254 @ .050" what's the adv duration? JIM68 Engine 7 Feb 4th, 03 09:31 PM
30-30 cam specs please JLD Engine 2 Dec 21st, 02 07:16 PM
