| Team Camaro Tech Current Topic: Voltage regulator .......isolated? | ||
| Electrical & Wiring Troubleshooting electrical. |
Does the voltage regulator on a 69 Camaro have to be isolated with rubber grommets , or can it be bolted directly to the firewall?I'm keeping everything stock if that helps.Thanks in advance for the vast storehouse of knowledge on this site.
bc |
| Sponsored Links | ||
Advertisement | ||
69 bolt directly to the radiator support. 67, 68 use the rubber grommets.
Dennis 69 Z/28. 302DZ, Autogear M22, Red w/black stripes. 69 Camaro, ZZ4, TH350. 8.5 3:42 posi, X11 87 IROC |
You might place an internal star washer underneath on of the chassis feet to pormote a good ground path.
When you get done mounting and plugging in the regulator, measure the continuity from the reg chassis to alternator case, should be less than 1 ohm of resistance.
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
Just to be clear, the regulator case MUST be grounded on all years. 67-68 use rubber well nuts to mount it, and require a separate ground wire from a predrilled hole in the regulator case to the rad support. 69's did away with the wellnuts and expect the reg to ground through the mounting bolts. Use a star washer, between the reg and the rad support, to make sure.
JimM's firstgens.com Camaro Board Jimragtop.com New website for my vert is coming together. Do ya like the slide show on the home page? |
I presume the rubber mounts were to isolate the buzz from the radiator support.
Dave ======================== 68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI |
Thanks for all the reponses.All of you are of great help!
Yes.
| Sponsored Links | |
Advertisement | |
Similar Threads
| Voltage regulator | Barry J | Electrical & Wiring | 38 | Aug 24th, 06 06:05 PM |
| weird happenings going on with voltage regulator | hotrodz/28 | Electrical & Wiring | 4 | Apr 12th, 06 09:04 PM |
| Voltage fluctuations | fletcher969 | Electrical & Wiring | 6 | Dec 16th, 05 11:37 AM |
| Battery Cables, Amp Gage, Voltage Gage, Voltage Regulators, Alternators ...oh my!! | Robert Stacho | Electrical & Wiring | 34 | May 23rd, 02 12:30 PM |
| Voltage regulator mounting | Peace69Z/28 | Tech 2000 | 6 | Mar 7th, 00 06:47 PM |
