How to "guess" current compression ratio - Team Camaro Tech
Old Sep 16th, 06, 10:57 AM
68427 68427 is offline
Question How to "guess" current compression ratio
I have an unknown build '68 427/390. Is their any way to estimate the current compression ratio?
I already know it runs fine on pump & is relatively mild...
What I really need to know is what pistons are in it. Can the be determined mearly by removing the heads? Or can I get a hint by removing the oil pan?
I'm trying to determine if the bottom end is going to support the build I'm planning.
Old Sep 16th, 06, 12:09 PM
JimM JimM is offline
Jim
Default Re: How to "guess" current compression ratio
Many piston manufacturers stamp the part # into the top of the piston. That number would go a long way in answering your questions.
Craanking compression in psi and cam specs could allow us to back into both your current DCR and your static comp, which would then (along with head casting #) lets us figure roughly how big a dome/ dish the pistons have.
Similar Threads
Is static compression ratio irrelevent? SooperDave Engine 27 Mar 5th, 07 11:11 AM
Compression ratio and HP for rebuilt 396/325 HP stope4 Performance 5 Dec 11th, 04 04:04 PM
compression ratio zack 68 Engine 10 Dec 29th, 03 09:01 AM
About Compression ratio and how to change it? Procharged69 Tech 2000 1 Mar 4th, 01 02:16 PM
Supercharging and Compression ratio? Procharged69 Tech 2000 6 Nov 1st, 00 12:07 PM
