Third Generation 1982-1992
Old Sep 16th, 06, 06:35 PM
etrigan420 etrigan420 is offline
Default 3rd gen gauge needle removal
ok, noob question, and first post here as well (Hi all )....
but how does one remove the speedo needle on an '86Z?
I've got a few bulbs out on the cluster and have figured out how to get all but the speedo gauge off. Is there a tool, or do I just need to pull harder?
TIA for any input.
Old Oct 13th, 06, 10:49 PM
69-er 69-er is offline
Larry
Default Re: 3rd gen gauge needle removal
Be carefull about pulling harder. I pulled on my needle until the shaft just snapped. However, with a little care, I put a drop of epoxy on the end of the shaft and supported the needle on the shaft until it hardened. It hasn't come loose in twenty years. The only problem is that I indexed the needle about 2-3 MPH off.
Are you trying to dis-assemble the speedo or just remove it from the cluster?
Larry
Old Oct 16th, 06, 11:08 AM
kniner kniner is offline
Wayne
I've just added white face to my 92. If your just replacing the bulb then you don't need to remove the needle. The bulb socket is in the back and it just twist off. The bulbs are then soildered in so you have to pry the little wires loose. I replace all my bulbs with green ones to set off the white face gauges. It looks great.
http://www.cardomain.com/ride/2483817
Wayne from NC.
Similar Threads
why is it so expensive to restore?? RUSTY69 Bench Racing 54 May 1st, 07 12:04 PM
Thought someone might find it usefel, others dishearting!! Parts list of my project! boilermaker Camaro Tech 20 Apr 7th, 06 10:14 AM
thinking about switching from 1st gen to 3rd gen tmannet Bench Racing 37 Nov 14th, 05 09:26 PM
Has anyone used a 3rd gen console in a 1st gen? MStennes Interiors 1 Apr 17th, 05 06:25 PM
Gauge Needle Removal robbm Tech 2003 2 Apr 26th, 03 05:11 AM
