'69 door hinge bolts - Team Camaro Tech
Restoration Corner Where originality comes first
Old Sep 17th, 06, 07:55 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Question '69 door hinge bolts
Just curious here, not picky at all....
This is the symbol on the heads of my door hinge bolts. They are the correct bolts with the correct washers for sure.
I saw somewhere that they should have a number on them instead, (22 or 23) but I know these are what came on the car.
What's right?
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Sep 17th, 06, 08:02 PM
Eric Kammerer Eric Kammerer is offline
Default Re: '69 door hinge bolts
Mine had the numbers, pretty sure it's 23
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Sep 17th, 06, 08:18 PM
Tinkerr Tinkerr is offline
I had two 68's one had a mix of 23's and P's on the bolt heads the other had P's on all of them. Apparently it varied depending on the supplier.
Old Sep 18th, 06, 04:18 AM
HwyStarJoe's Avatar
That's what I figured.
Thanks guys.
SEMA ACTION NETWORK
Similar Threads
69 reassembly advice? 69454 Body Shop 3 May 22nd, 06 12:10 PM
difference btwn threaded studs -vs- bolts (oilpan) Liveinaz Engine 7 May 4th, 06 02:53 PM
69 top rear shock plate? ck 2 Brakes, Suspension & Steering 2 Oct 16th, 05 05:50 PM
U Bolts - 10 bolt - 8.5 - GM Corporate drew69 Brakes, Suspension & Steering 2 Nov 9th, 03 02:00 AM
WANTED: 67-69 Camaro to install T56 six speed in. Teetoe_Jones Tech 2000 2 Dec 31st, 00 05:23 PM
