Best Welder? - Team Camaro Tech
Body Shop Paint & Body Forum
View Poll Results: Which Welder do you Prefer?
Lincoln 17 35.42%
Miller 27 56.25%
Other 4 8.33%
Voters: 48. You may not vote on this poll
Old Sep 18th, 06, 09:09 PM
Camaro Dave Camaro Dave is offline
Default Best Welder?
I'm in the market for a welder for doing body work, welding panels, etc. nothing heavy duty. Which is the best type of welder and best brand for the job? ARC, MIG, TIG, Lincoln or Miller? What are you using?
67 RS Camaro 327/ 350 Holley 650cfm > Edelbrock Performer Intake > Pertronix Ignition > Accel Super Stock Coil and Wires > Hedman Hedders > Hotchkis Performance Springs > 15" Rallys all around
Camaro buds until the end!!!
Old Sep 18th, 06, 10:28 PM
1969ss 1969ss is offline
Rob.
Default Re: Best Welder?
The millermatic 135 plugs into a regular outlet, mig with .23 welding wire and co2 argon mix.
The lincoln is pretty good also, but the wire drive wheel is plastic on the lincoln and metal on the miller.
Either one will weld anything on a car, including the frame.
Hobart is pretty good also, but I don't think you can fine adjust your controls as much as the other two.
I had a miller 110 mig sidekick for about twenty years, no problems with it, gave it to my boys and bought the millermatic 135, same machine just newer and smoother, after so many years will weaken a little.
Another thing with the 110's are the duty cycles, you have to stay within them where a larger machine you don't have to stop welding and wait.
My neighbor went to bodyshop technical school 3 or 4 years ago, there was 23 of them in his class, all they trained on was a 110 mig, the millermatic 135.
Some like a tig, but they say it's harder to learn how to tig weld. I don't know anything about them, good or bad.
Hope some of this helps you out.
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
Old Sep 19th, 06, 04:09 AM
reelmcoy reelmcoy is offline
Tech Team
I have a Lincoln and it has steel drive wheels, not plastic. Any of the three mentioned above are good. I have a Hobart 135 that has worked well for me. I replaced it with a Lincoln 220 volt 200 amp for the duty cycle. I am in the collision industry and can't wait on a 110 unit.
Old Sep 19th, 06, 05:49 AM
Daral Daral is offline
Daral
I use a Miller 135. It is easy to adjust and for my limited use, I have never had to wait for the duty cycle.
Daral (67 RS/SS 350)
Old Sep 19th, 06, 07:11 AM
jet_car2000 jet_car2000 is offline
Frank
Dave if you can find a autoarc welder they are the same as a miller 135 and about 200 bucks cheaper and made by miller,,,,
Old Sep 19th, 06, 08:52 AM
Rob.
reelmcoy, you probably have an older lincoln, lasy years new lincoln have the plastic one, but the plastic one might be as good as the steel one.
Rob
Old Sep 19th, 06, 09:00 AM
clwilcox33's Avatar
clwilcox33 clwilcox33 is offline
Christropher
I think it's only the 110V Lincolns that have the plastic drive wheel. The larger 220V ones I've been told are metal. All of the Millers are metal.
Christropher
1967 RS/SS 350...in pieces still.
http://www.67rs-ss.net/
**How to attach images**
MrDanB - "Don't worry about Mr.Wilcox...He has that incurable disease of thinking that they only made the Camaro in '67 "
Old Sep 19th, 06, 09:18 AM
dsherw00d dsherw00d is offline
Dan
I bought a factory refurbished Lincoln SP-100T with the standard 3 year factory warranty. It was one of thier demo units. It works great - much better than me I bought it on line from a place that had free shipping and great support. One of my guages was broke and they sent me a whole new regulator with both guages next day. I didn't even have to mess with sending the broken one back.
-Dan
http://www.thesherwoodgang.com/cars/
Old Sep 19th, 06, 10:09 AM
ahowudoin ahowudoin is offline
Tech Team
Ken
I had a 110 and sold it and bought a miller 210 and love it. I also have a lincoln tig/arc.
Old Sep 19th, 06, 01:05 PM
69vert 69vert is offline
Bob
Lincoln and Miller are just about the same. Miller uses metal drive wheels in their MIG machines. I would buy a TIG, just for the versatility, steel, aluminum, stainless, titanium
Bob
Old Sep 19th, 06, 01:09 PM
Silver69Camaro Silver69Camaro is offline
Matt Jones
Bob
TIG is pretty tough for body panels! IMO, MIG is the only way to go for general purpose welding.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Old Sep 19th, 06, 02:39 PM
Johnny B Johnny B is offline
The lincoln sp135T is about $150 cheeper than the Miller 135. However, The Miller does have infinate variable voltage control where the Lincoln only has 4 voltage settings. Although, after you get used to the machine the pre-set voltage really isn't a problem. Either Mig machine (with gas) will do well for body panel replacement and fabrication. I own the Lincoln sp135T, but if I had to do it again I would buy a little larger machine like the Millermatic 175/220v or larger...Jb
Beat it to Fit, Paint it to Match!
Old Sep 19th, 06, 03:11 PM
fladoans fladoans is offline
Steve
I vote Miller. Don't have much experience with the others, but I have a Miller 275 and it's perfect for the car. Will weld almost anything. It does have the metal drive wheels and I have had no problems in the year I have owned it.
Steve
69 Camaro
Old Sep 19th, 06, 05:15 PM
Wow, Thanks for all the different opinions and great info you guys have on welders........it gives me something to consider.......price, usage, arc/gas, duty cycles, etc...... I was leaning towards a Miller........ still am. I have a friend who said that Miller is the best welder on the market. I guess it's a matter of opinion. It looks like Miller is leading in the poll which means they must be good. I'm sure Lincoln is good too, but Miller is more popular.
Old Sep 19th, 06, 06:07 PM
HarleyD67's Avatar
HarleyD67 HarleyD67 is offline
Harley D
If money is not an issue then I stand behind my Miller vote. But I have a Lincoln and in my opinion there the best welder for the money.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.7281/4-11.83@115.59
firstgens.com
Similar Threads
Quick advice - Campbell Hausfeld MIG Welder pawn shop special Chuck78 Body Shop 5 Jun 20th, 05 10:04 AM
I was thinking of buying these welder parts.. will they work? victimizati0n Body Shop 8 Jun 16th, 05 07:24 PM
Best welder for $350 Tom Ziokowski Bench Racing 10 Dec 27th, 04 03:58 PM
Welder Johnny Boy Body Shop 3 Aug 27th, 04 03:35 AM
Mig welder Johnny Boy Body Shop 6 Jan 14th, 04 02:53 PM
