how to replace front seal + bushing TH350 - Team Camaro Tech
Thread Tools Display Modes
Old Sep 19th, 06, 04:21 PM
Rayzz Rayzz is offline
Default how to replace front seal + bushing TH350
I am getting ready to install TCI saturday nite special torque converter. I would like to replace front seal and bushing if needed. Can someone help me find a how to. Or can you tell me how. Engine is out of car but trans is still in.
THANKS RAYZZ MY CAMARO LIKES MY MONEY
Old Sep 19th, 06, 04:27 PM
Default Re: how to replace front seal + bushing TH350
Also can someone tell me what the stock torque converter stall speed would be for a 67 big block 396 325HP Camaro.
Old Sep 19th, 06, 11:12 PM
ChevyCam ChevyCam is offline
Mike
You're not going to be able to replace the bushing easily unless you remove the whole trans pump assembly and dissasemble it so you can drive out the bushings. The front seal though is easy to remove with a seal puller (T-shaped tool with hooks on the end) then you can tap in the new front seal. Make sure it goes in square.
Mike
68 Camaro (Resto in Progress)
Old Sep 20th, 06, 04:28 AM
Everett#2390's Avatar
<Jake-68's rule
Lube the seal lip and pump driver of the t/conv before sliding on the torque convertor.
Old Sep 20th, 06, 04:41 AM
The bushing in the trans is damaged. I am going to have to remove . Can someone tell me how to do this and parts needed.
Old Sep 20th, 06, 11:45 PM
Mike
Probably easiest to do this with the trans out of the car and mounted to a stand. You're going to have to remove the pump from the transmission. You can either do this with a pump remover OR you can remove the bolts and get two slide hammers and thread them into the threaded holes and gentlty pop the pump out.
Once it is out, I really recommend taking it to a trans shop to get rebuilt because there are soft and hard parts inside that should get replaced when you have it apart.
But if you really want to rebuild it yourself, I recommend picking up an ATSG manual on the th350 to give you a step by step.
http://www.atsg.biz/cgi-bin/shopper....e=&passsubnum=
You'll need two special tools: a pump alignment band and something to drive in and out the bushing, such as a socket.
Mike
Old Sep 21st, 06, 04:41 AM
I removed trans from car and went to TRNS shop they charged me $20 and its done. I hope . I am slso cleaning it up will it is out.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: how to replace front seal + bushing TH350
Location
Location
First Name
Human Verification
Similar Threads
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 11:50 AM
Suspension Parts List davidpozzi Brakes, Suspension & Steering 3 Feb 23rd, 04 02:54 AM
Front subframe/rad support bushing.... why not solid ? DRJDVM Brakes, Suspension & Steering 11 Jul 23rd, 02 05:27 PM
Convertible Header Seal Replacement 68.camaro Body Shop 1 Aug 14th, 01 07:09 AM
