Body Shop Paint & Body Forum
Old Sep 23rd, 06, 05:53 AM
ray moore ray moore is offline
Default Buying an air compressor, basic questions.
I am looking to buy an air compressor and have some basic questions on what features and options I should evaluate. My main goal is to attempt to paint a car ( my wife's ) and also use it for air tools ( socket wrench, grinders etc). I am going to shoot the subframe and under body of my Camaro first and then move up to try and paint my wife's car. My budget is around $500-700 for the compressor and then try to find a good low price spray gun. I have looked at compressors locally ( Tractor Supply, Lowe's, Home depot, Sears and have some questions)
Dryer:
I have seen that you need to put a moisture trap or dryer in line when painting, What am I looking for and where to buy?
Compressor questions,
1. Average tank size is between 60 and 80, I know bigger is usually
better but is this a critical buying point.
2. How much CFM should I be looking for at 90 pounds that will be enough
for what I want to do.
3. Single stage or two stage motor, critical buying point?
4. It seems a big price difference depends if the Maximum PSI is 135 or
175. A big deal or not?
5. Most seem to be rated for Continuous duty, I'm assuming that is what I
want.
6. Any other things I should be looking for when comparing compressors.
7. The Tractor Supply carries Ingersoll Rand , is this a good brand ?
Does anyone have compressors that they bought from Tractor Supply,
Sears, Home Depot or Lowe's that they like.
8. Spray Gun question. Good lower price Gun ( around $200-300 )
What brand? What Model?
Ray Moore
Old Sep 23rd, 06, 05:58 AM
wyoming T/A wyoming T/A is offline
Darrell
Default Re: Buying an air compressor, basic questions.
bigger tank [80] isbetter. 14 or 15 cfm would plenty good enough
Old Sep 23rd, 06, 06:06 AM
Here is a link to one I was checking out at Tractor Supply
http://www.mytscstore.com/detail.asp...45312&x=12&y=9
Old Sep 23rd, 06, 10:10 AM
CDJr CDJr is offline
CDJr
That is a good compressor with very good specs, ray. If ever there was a situation that the old adage "bigger is better" applied to, itd apply to compressor output. The reason you want as much CFM as possible is because a compressor that is pushed to its limits, even if it does keep up, will also create moisture problems, as the more it runs, the more moisture problems arise. Not to mention a shorter lifespan. So you would have fewer moisture problems with one that produces 20 CFM than you would with one producing 12 CFM, using the same air tools, if that makes any sense. And when it comes to painting, moisture is the primary enemy.
Old Sep 23rd, 06, 10:14 AM
clwilcox33's Avatar
clwilcox33 clwilcox33 is offline
Christropher
Ingersol Rand is a very good brand.
Christropher
1967 RS/SS 350...in pieces still.
http://www.67rs-ss.net/
**How to attach images**
MrDanB - "Don't worry about Mr.Wilcox...He has that incurable disease of thinking that they only made the Camaro in '67 "
Old Sep 23rd, 06, 10:20 AM
zdld17 zdld17 is offline
Team Member
Don
I like the larger tanks, 60 and up . I prefer two stage and cast iron bodies. Water traps etc and 220 volts. Pulls about 50% less amps. Perferrable with a starter capacitor. . You can also hook this aside the breaker that your welder is on. Try for a low rpm driver and large bull wheel on the compressor. Hook up pressure unloader also. I have seen some good ones at Harbor Frieght, tall space saving models. The 60 and larger horzontial fit well under a bench . Need to determine where you will put it as noise from this thing will be an issue. Need to have a good intake filter / silencer.
I/R is a good brand. Be sure what ever you have , has a tap for bottom water drain.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Sep 23rd, 06, 12:55 PM
JimM JimM is offline
Jim
when it's time to paint, get a bunch of those plastic tennis ball filters. They attach at the gun, I think they're filled with toilet paper or something. Throw it away and put a new one on after every 30-45 minutes of spraying. Not a molecule of water will get thru it.
Also be sure to use an "at the gun" pressure guage. Guage first, then the tennis ball, pressure drops, you need a new tennis ball.
former TC moderator, who really hope nobody here thinks I paid for or asked for this lifetime gold membership
Old Sep 23rd, 06, 01:16 PM
CDJr
Pardon my ignorance here, but what the heck is a tennis ball filter?
Old Sep 23rd, 06, 01:53 PM
HarleyD67's Avatar
HarleyD67 HarleyD67 is offline
Harley D
Very good choice in compressor.
Very good cfm rating
Cast iron pump
240V (110V wont cut it)
80gal tank (bigger is better in this case)
Good brand
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.7281/4-11.83@115.59
firstgens.com
Old Sep 23rd, 06, 04:27 PM
Thanks for all the feedback, Besides the one I picked from Tractor Supply not being a 2 stage everything else sounds like a good choice. They do offer another that's one stage up that is 2 stage, I'm just not sure if the differences are worth $250 more. Also like CDJr say's, What's a tennis ball filter and where do you get one. Anyone have a choice of Paint guns?
http://www.mytscstore.com/detail.asp...productID=1270
Ray
Old Sep 23rd, 06, 05:24 PM
dsherw00d dsherw00d is offline
Dan
I think it's a desiccant filter to remove some water. Has anyone every used anything like the below? I'm going to need somehting soon and have been looking around. Do the snakes work any better than the well known tennis ball?
http://www.sjdiscounttools.com/dev130502.html
http://cgi.ebay.com/ebaymotors/DEVIL...QQcmdZViewItem
http://www2.northerntool.com/product..._200319833.htm
-Dan
http://www.thesherwoodgang.com/cars/
Old Sep 23rd, 06, 06:32 PM
Jim
I am not finding a pic of one on the net...
The first ones I bought came from my paint supplier. I asked him the best thing to get the water out of my air, he recommended a $100 air separator...and didn't have it in stock. I asked what he had and he handed me a blister pack with 2 things that looked like tennis balls.
They had a male pipe fitting on one side, female on the other. The label said they were disposable, so I don't think they were desicant, you can dry those out and reuse em. The paint store ones were orange, I later bought more at Napa, they were blue.
The damned thing flat work tho, and they cheap.
I got a smallish compressor, and it runs nonstop. Even with 2 water separators at the compressor, enough water comes thru the hose to freeze up my die grinder. With the tennis ball, ZERO condensation comes thru.
Old Sep 23rd, 06, 07:07 PM
Mike68RS Mike68RS is offline
Mike
I think these are what you're talking about Jim.
http://www.hechinger.com/hardware/to...er-mp3278.html
Mike
68 Camaro RS
Old Sep 23rd, 06, 07:17 PM
Jim
yup, dem's da ones I got at napa.
The paint store ones were same same but a different brand and color.
Old Sep 23rd, 06, 07:35 PM
69-Z11Pacer 69-Z11Pacer is offline
Bill
Ray,
I own that EXACT compressor. I also bought mine at tractor supply. It's awesome, not overly loud, and can keep up with just about anything I throw at it. I've even had two hoses hooked to it with 2 sanders going, and no problems.
I give it a 9+++ out of 10.
Bill
Classsic Performance & Restoration
http://www.cpresto.com
Similar Threads
Aftermarket carbs and stock air cleaners? Darin Imbriaco Engine 5 Jul 9th, 05 08:15 AM
Air Temp/Jetting freebird Performance 2 Jun 20th, 05 10:29 PM
"Basics of Basics" Buying tools MARTINSR Body Shop 33 Jun 8th, 05 07:23 AM
Questions before I buy a COPO Clone blownNinjected Copo & Dealer 27 Dec 6th, 04 07:11 PM
