Intake For 406 SBC - Team Camaro Tech
Old Oct 1st, 06, 10:54 PM
raceboy raceboy is offline
Default Intake For 406 SBC
Has any one did any testing with intake manifolds? I have brodix track 1 with sock block and scat I-beams and scat crank and Mahle flattop pistons and power plus intake that I ported out my self . The car gose lean mid range to top end? It Bg 400 pump with -10 line going up to the front. The best run so far is 10.94 @ 121mph
Old Oct 2nd, 06, 07:14 AM
Greg O Greg O is offline
Default Re: Intake For 406 SBC
I tested the Performer RPM vs. the Vic Jr. but I don't think that's relevant for you. You are probably looking to compare different single planes I guess?
69 Camaro, 3450lbs., 406, Cal Tracs, Coan 10", 3.73 gear
D1SC blow thru, pump gas, 9.3:1, ~8 PSI,
1.319 60', 6.005 @ 115.4
Old Oct 2nd, 06, 07:29 AM
Eric68 Eric68 is offline
Eric
Why would the intake effect mixture at different RPM's? As long as the distribution is even cylinder to cylinder you should be able to tune through any RPM related issued with HS air bleed changes (possibly emulsion holes if the bleeds don't do it).
Not sure what carb you are running but you could start with a smaller HS bleed -- I had a similar problem with an annular booster 800 Mighty Demon and wound up going from .040" down to .0285" on the HS bleeds to flatten the curve out.
PS. You may want to verify your fuel pressure before messing with the bleeds . . . sounds like you have a killer fuel system but you never know . . .
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old Oct 2nd, 06, 07:51 AM
67RS502 67RS502 is online now
The fuel distribution can be bad on some single planes, (dont know what you did
as for porting, but did you do any plenum work - you can fix it or make it worse)
A 1" open spacer will help fuel dist. problems, but a 4-hole will make it worse.
Dont know if that has anything to do with it going lean? you sure its not the carb?
Since youre makin decent power, I'd go with a Super Victor, or Motown, either
will be good on a street/strip 406.
67 camaro 373s:
420 - 641hp HRcam 1.40, 9.90 @ 135
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
Old Oct 2nd, 06, 12:37 PM
Dirt Reynolds Dirt Reynolds is offline
Silver Bullet
Greg, what was the result of your testing the RPM vs. the Vic Jr?
Silver Bullet
1977 Z-28
*New 408 - no ET's yet.
*413 Phase 6 heads Comp 306S Vic Jr 3310 Holley 11.73@115.10 on drag radials @ 3725 lbs.
*Vortecs 234/244 Crane RPM intake 3310 Holley 12.15@110.52 @ 3760+ lbs
Old Oct 2nd, 06, 01:04 PM
DOUG G DOUG G is online now
RedЯuM
So far I like the Vic Jr. I'm running. Buddies 383 w/ a Vic Jr. at 10.2X's has been woking for him also.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Oct 2nd, 06, 06:42 PM
I am running a annular booster 850 Mighty Demon I change power valve to 2.5 and jets sizes to 90 & 97 in the back. On my intake all I did was port match it to the heads. I think I'm going to play around with the air bleeds and I also just got a Wilson 1" spacer I'm going to put on. ????
Old Oct 3rd, 06, 05:47 AM
Dirt, For me the Victor Jr. worked best. I lost maybe .01-.02 on the 60' but picked it up and then some by the 330' and beyond. I gained some nice MPH too.
I will say that others have had different results (much better 60' with the RPM) but I did not. A lot of it depends on your converter. A dual plane makes a lot more torque below the torque peak RPM but a single plane will out perform it above torque peak. My combo at the time had a torque peak around 4500. My stall then was 4200 so I spent virtually no time below torque peak so the single plane out performed it dual plane. If you have a tight converter the dual plane may work better for you.
I really could not tell any drivablility difference either. The theory is that a single plane will not be crisp off idle but mine is fine.
Old Oct 3rd, 06, 07:13 AM
1969 RS/SS DROPTOP 1969 RS/SS DROPTOP is offline
Paul
Thumbs up Re: Intake For 406 SBC
A holley 300-25 with a 2 inch spacer or a victor jr with the spacer is a nice set-up. Both run quick for me.
Old Oct 3rd, 06, 01:35 PM
Silver Bullet
Greg, thanks for the reply. I too run a Vic Jr, I was just curious as to how it stacked up against your RPM intake. Looks like you got it working great for you.
Silver Bullet
1977 Z-28
Old Oct 3rd, 06, 07:11 PM
68sixspeed 68sixspeed is offline
Dan
Victor Jr is an awesome intake, has a lot more bottom end torque capability than a lot of people give it credit for too, the only down side if there is one is the runner size/cross section seems to cap off around 550hp; I made my best pulls with my '358 with the victor jr (550hp on it's best tune), but when we built the '427sb this year the super victor made serious power gains- put it this way, between tests we raised the compression just under 1pt, and went from the super victor ported by Wilson, gained over 60hp! 1pt of compression should have been around 3%, or 15-18hp of the gain, So, if you are running a big cc head and large roller cam, you might even want to test a super victor. Street manners are still very good too.
68 RS/SS Camaro, LS7/T56
68 RS Convertible project "what was I thinking" (Stock Resto)
2006 Corvette Z06
2011 Corvette GS Convertible
Similar Threads
just got my new intake in for the BBC...i want to cry 67stang Engine 11 Nov 7th, 05 07:05 PM
Garage find... '81 Z28 aluminum intake HwyStarJoe Engine 16 Feb 15th, 05 08:19 AM
pro action (pro topline) intake gasket solution 68rs406 Performance 4 Aug 16th, 04 03:28 PM
Intake Gasket Woes rojo Engine 5 Sep 22nd, 03 03:11 AM
Help with intake leak causing oil smoke 68SSConvt Troubleshooting 3 Jun 8th, 02 03:26 AM
