Hurst Reproduction shifter - Team Camaro Tech
Old Oct 4th, 06, 07:50 AM
Ryan Windham Ryan Windham is offline
Tech Team
Default Hurst Reproduction shifter
Has anyone tried this Hurst repro shifter. I see that it is stated to "perform like the original". Does that mean that it is a crappie as the originals. It is well known that the original GM factoy equipped Hurst shifters were problematic and very often changed out for Hurst aftermarket shfiters.
http://www.ss396.com/mm5/merchant.mv..._Code=HURST-69
Old Oct 4th, 06, 04:28 PM
JOE58 JOE58 is offline
Default Re: Hurst Reproduction shifter
from the not so clear picture it looks like it is a standard aftermarket Hurst shifter except has a reproduction round stick. The aftermarket Hurst shifter and rods are completely different then the original 69 Camaro Hurst assembly. It should work the same as the flat stick aftermarket Hurst shifter. Would be good for a driver but not for a judged show car.
Similar Threads
No Hurst Name On 68 Shifter??????????? gonewacky Transmission & Driveline 9 Sep 13th, 06 05:33 PM
Hurst Shifter Mounting Plate and Linkage Cameron Transmission & Driveline 2 Mar 3rd, 03 06:23 AM
Muncie and/or hurst shifter trouble. please HELP Marc Engine 10 Nov 12th, 02 09:08 AM
Muncie and/or hurst shifter trouble. please HELP Marc Troubleshooting 0 Nov 10th, 02 12:53 AM
A trick to fix hurst shifter noise/rattles!! cody Engine 2 Feb 6th, 02 02:26 PM
