Ha I got the First question. - Team Camaro Tech
Pro Touring Todays performance with classic style
Old Oct 5th, 06, 07:32 PM
sharpie sharpie is offline
Rich
Talking Ha I got the First question.
Any body using a Fatman subframe assembly?
Rich
68 Camaro convertible
67 SS Chevelle Wagon 350,TKO 5 Speed,True fire flame job
You grin ear to ear driving this bad boy!
http://i140.photobucket.com/albums/r...rgeWebview.jpg
Old Oct 5th, 06, 08:16 PM
baz67 baz67 is offline
Default Re: Ha I got the First question.
I thought this was about pro-touring? Fatman is great for cruisers or showcars, but you can do much better elsewhere for your money in a PT application.
Their website states that their frame NARROWS the track width by 2"!!! What?? That is not what you want to increase lateral grip. My guess they do that so you can put a deeper dish front wheel on. That is all dandy if you want the look, however it increases scrub radius by 1" per side. That is another thing you do not want in your first gen. It also looks like the amount of negative camber is limited by the design of the mounts. That may or may not be an issue. It depends on the amount of design static camber.
You could put half the amount of the Fatman frame in your stock frame and have better performance.
Old Oct 5th, 06, 08:30 PM
Rich
Now thats what I want to hear, what would be the best set up for a nice P/T?
I plan to drive the crap out of mine, no garage or trailer queen here!
Rich
Old Oct 5th, 06, 09:25 PM
67bird 67bird is offline
Ben
Cheapest solution would be better bushings and the G-mod. From there the sky is the limit on what you want to spend. You may want to check out ATS. There tall spindle allows you to use Corvette C5/C6 brakes and according to there numbers is better than the G-mod. They run around $700.00 a set and include new corvette hub bearings.
_____________
Ben
67 Firebird
Old Oct 6th, 06, 07:37 AM
Joe Harrison's Avatar
Joe Harrison Joe Harrison is offline
67 Camaros Rock
If you ask me ATS is the way to go. You get the camber and G-mod all for $700 and don't have to cut weld or anything just bolt on and you can use your stock subframe and upper and lower control arms. Just go witht he del-alum bushings in them. The next mod for me would be shocks, maybe the QA1 coil overs or set of bilstien or Koni's. You can do front and rear brakes, ATS spindles, bushings and good shocks for less than 3K. Then all you need is wheels and skys the limit there. Call ATS, that set up with C5 brakes is the best bang for the buck in my book. I will be using it on my at some point. Only draw back is you need to use the true c5 brake which makes it nessary to have a TRUE 17 inch wheel. Not a wheel witha 16 inch center and 17 inch outer.
Joe
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
Then, you have enough horsepower."
-Mark Donahue
My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805
Old Oct 6th, 06, 09:22 AM
MStennes's Avatar
MStennes MStennes is offline
Mike
If were going to subframe a Camaro it would go with Detroit Speeds subframe. Now the way I went was a GW coil over conversion, GW upper and lower control arms, Hotchkis front sway bar and a Uni-Steer R&P, with Baer brakes. I'm going to ATS this winter for their spindles and DSE subframe connectors (I'm removing GW's not that their bad but because I have a vert and I'm installing a LS7 so I need more stiffness). For a driver though you cant go wrong with GW or DSE or even Hotchkiss. By going with Fatman or Hiedts your getting a wow factory but nothing better than the stock setup. You can modify the stock sub to do anything you really want for a hard driver. The only limitation on the stocker without allot of modding is not being able to run a 275 up front. Do you want to spend your cash for bragging rights or to really tear up the road? Their are allot of real fast cars on and off the track running the stock subframe and rear leafs. Just get real good parts from the better mfgs. I have been done the road, still there always changing this or that. If I can help let me know.
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Welfare is completely against freedom and the principles of american life, paying people not to work by stealing from the people who do is insanity.
Old Oct 6th, 06, 07:41 PM
Rich
I want mine to be like a slot car, Tear up the roads of coarse!
Its also a vert. Gonna have to stiffen her up.
Rich
Old Oct 6th, 06, 09:37 PM
MStennes's Avatar
Mike
Theres allot you can do, I think I have made every mistake what have you done so far? Maybe I can save you some headaches and cash.
Old Oct 6th, 06, 11:04 PM
Rich
NOT a thing my friend, got it under a blue tarp, Planning ahead, looking for ideas!
Rich
Old Oct 7th, 06, 10:27 AM
If you want a parts list for IMHO what would be the ultimate set up for a first gen subframe here it is.
DSE coilover conversion
GW upper control arms
ATS tall spindle
Hotckis front sway bar
DSE or ATS power steering box
Wilwood, Stoptec or Brembo 13" 6 piston front brakes
Koni, Bilstien or Penske shocks
600lb front springs for Al headed SBC
GW lower control arm del-a-lum bushings for stock lowers
Start by putting the coilover kit so the holes match the factory mounting location. The advantage of the kit it it opens the door for a wider range of performance shock/spring combos as well as height adjustability. You want it in the factory location because the ATS spindle and GW uppers were designed around that location. If you were to put it at DSEs location you would end up with overly aggressive geometry. The GW uppers for the bushings and added caster. The ATS tall spindle for the much improved camber gain and the ability to use any C6 brake package.
There is a reason why two of the leaders(ATS and DSE) for first gen suspension do not offer a rack and pinion. They cannot make one peform as good as an updated steering box for that application. That is not to say that R&P cannot be better in the right platform but, there are too many packaging issues is a first gen to do it right.
Depending on the brake and shock package all of that can hit the 6000 mark. You can get damn good perfomance as well as knocking down the cost somewhat by knocking out the DSE coilover kit, using correctly valved Bilsteins and a factory C6 brakes. That will be around 3000.
Old Oct 7th, 06, 12:51 PM
ZZ430DropTop67RS's Avatar
ZZ430DropTop67RS ZZ430DropTop67RS is offline
Don
DSE subframe with R&P
Don ~ TC Member #15 ~ http://www.flickr.com/photos/46701464@N06/
Old Oct 7th, 06, 02:23 PM
MStennes's Avatar
Mike
ATS tall spindle
Brian, thats a good list but I would go GW coil over kit, its just as good as DSE's (IMO), and go with a Uni-Steer R&P. You also forgot Baer Brakes, if your not going all out racing those are more than enough. I also would add that grinding and rewelding the subframe and it would be just as good as the best aftermarket and better than most aftermarket subframe available. Its only downfall would be weight and not being able to run 275 fronts without further mods. Dont forget to run Del-A-Lum on all of the suspension pieces and sold subfame mounts. DSE's subframe connectors cant be beat either. I'm running QA-1's and they are starting to amaze allot of people at how god they are. For the rear I would deep tub it, use a DSE relocating kit with GW Catagory 5 rear springs.
Old Oct 7th, 06, 03:20 PM
Rich
[B]ZZ430DropTop67[B] Looked at your pictures, How does your car handle,Thats about what I am looking to do, And how stiff is your body (flex) No shots of frame ties.
Great stock look with attude!
Rich
Old Oct 7th, 06, 04:29 PM
I did not take the new DSE subframe because I was talking about the stock sub. DSE made it work because the R&P taken into account with the design.
MStennes,
I agree the QA1s are an option, but the DSE kit opens up much, much better shocks for the front end.
Old Oct 7th, 06, 04:38 PM
MStennes's Avatar
Mike
MStennes,
Brian,
I agree but I didnt know what to think on QA-1's when I first got them and low and behold their pretty dang good, I have ran Bilsteins and inmo I think the QA-1's were just as good if not better, I like the adjustability. The way I look at it at a certain point if your hard core racing/track use it gets to be a point where all it is, is bragging rights. My car being a convertable there is only so much you can do. I have talked to a few people who have actually talked me out of ding things as the gain was not there unless I was going to race my car. I swaer I have been down that raod twice and now I'm getting ready for a refit..... As far as getting straight answers no one can beat Tyler at ATS even if its not his product he will tell you.
Thanks,
Mike
Similar Threads
am fm radio question flyers69 Electrical & Wiring 3 Jun 28th, 05 08:31 PM
carb and exhaust question for 67 RS small block Kyson Engine 2 Jun 25th, 05 12:40 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 06:08 PM
Front glass install question Brackneyc Body Shop 12 Jun 11th, 05 10:40 AM
Really off topic paint question Winch Body Shop 6 Apr 26th, 05 08:32 AM
