| Team Camaro Tech Current Topic: 1969 X77 Z28 Car - I have a lead on one, what it worth? | ||
| What's it worth? & ebay discussions |
I am able to get an X77 Z28
the car does not ahve the 302 or 4 speed however it does have the disc brakes and 12 bolt, it will need a restoration, floor pans etc but isnt that bad what should I pay thanks |
I have seen projects like you describe going for outrageous money. An easy X77 project, sans motor and tranny should fetch upward of $25K. If nicely done, the finished project will fetch $75K.
This should be in the new section 'what's it worth'
Al just added it on Thur. and its been well received. Maybe DjD or Al can move this over there.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto. "There will come a time when you believe everything is finished, That will be the beginning." Louis L'Amour Our Camaro Webpage Photos for viewing Learn How To Post Pics here |
yeah it is not too bad, my father went to see it today I will look tonight on the way home
car has a drum brake front end now, doesnt have its motor or trans
it def is an X77 car needs quarters but nose, doors are good, floors mostly good still has the original 12 bolt what is it worth? thanks! |
...bump
please give me some ideas thanks |
Pictures? It would make things easier.
Rob SIM Member Nov 08 Nov 68 69 Z-28 X-77 HO * DZ Put away * 406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200* CC 1.52 Pro Mag RR* Perf Air Gap * Eagle 4340 Crank/Rods * Sep 07 -12.68 @ 113 1/4 * Oct 08 116.2 MPH Last edited by satz28; Oct 11th, 06 at 11:34 AM. |
Are you sure it originally had disk brakes?
Stock '68 Camaro L48 M20 3:31 LeMans Blue Coupe, black deluxe int, console w/gauges |
put this in the WIIW section
Jim Rohn Scottsdale, AZ 70 M22 Z28 34 Ford original |
With out seeing it, I would say $15,000 or a little more. You will have $35-40,000 in it to do it right, assuming a lot of the work is done by you.
Gary, SIM TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original. http://www.camaros.net/showroom/data/500/DSC00005.JPG http://www.camaros.net/forums/image....3&type=profile http://www.camaros.net/showroom/show...0&ppuser=11189 Last edited by Gary L; Oct 11th, 06 at 06:57 PM. |
#11
oh,,,were discs an option for 69 Z28s? thought it was standard.....
#12
Standard for Z/28. He was asking if you though it originally had disk brakes since it has drums now. Check for the valve mounted on the frame rail under the driver door.
Gary, SIM TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original. http://www.camaros.net/showroom/data/500/DSC00005.JPG http://www.camaros.net/forums/image....3&type=profile http://www.camaros.net/showroom/show...0&ppuser=11189 |
#13
the car had been stripped this car, def is a z28 that was put back together ....with the wrong stuff
#14
thanks for the info!
#15
Specificly pictures of the Cowl Tag, floor shifter opening, rear axle codes and the firewall details ...
These and other body photos arre the only way others can give you a heads-up on the car and get closer to a real value. Otherwise it's worth what you think it's worth - it's your money. The next guy you try to sell it to may disagree with your investment
1968 Convertible Some trucks Other things - some of which float ... Eagles may soar - but Guinea's don't get sucked into jet engines ... It's never to late - okay, maybe now it is ... WE NEED MORE COW BELL !!! |
Similar Threads
| 69 camaros on television and movies | jsg1010z | Bench Racing | 30 | Dec 3rd, 07 02:05 PM |
| Outlaws At Atco 9/23-24 10k To Win, Car Show Too | 351RAY | Team Camaro Cruiz-Ins | 1 | Aug 21st, 06 08:02 PM |
| X77 Z28 without power brakes? | jhilts | Camaro Tech | 2 | Feb 20th, 06 11:13 AM |
| July 30th Classic Car event & muscle car race at E- Town | SUPERGONZO | Bench Racing | 0 | Jul 31st, 05 12:21 PM |
| Tilt Steering in 1969 Z28 Camaro | jlighthart | Brakes, Suspension & Steering | 4 | Jun 8th, 05 08:45 PM |
