 Ground Up Restorations
Second Generation 1970-1981
Old Oct 15th, 06, 06:16 AM
Dirt Reynolds Dirt Reynolds is offline
Silver Bullet
Default How quick is your 2nd gen Camaro?
Welp -- my best thus far as been 11.73 @ 115 on a worn set of BFG drag radials. Over 3700# race-ready, 413ci small block (.060"-over 400), Comp 306S solid FT cam, Vic Jr, Bow Tie Phase 6 heads, 3310 750 Holley, TH400 trans with 2800 stall, and 4.10 gear. More left in it, but broke a piston on the last run of the year in '04. Fresh 408ci motor installed in May this year, but have had issues throwing belts at the track on the 2 outings I had, in addition the carb and timing aren't dialed-in yet so still working on that. Have a new carb (Holley 830 annular) and new converter - B&M Nitrous Holeshot 3600 which I bought because of all the heavy duty features including the anti-ballooning plates front and rear, which is important for thrust bearing longevity in a 400.
So -- how quick is your car? Look forward to reading about others' 2nd gens at the track.
Silver Bullet
1977 Z-28
*New 408 - no ET's yet.
*413 Phase 6 heads Comp 306S Vic Jr 3310 Holley 11.73@115.10 on drag radials @ 3725 lbs.
*Vortecs 234/244 Crane RPM intake 3310 Holley 12.15@110.52 @ 3760+ lbs
Old Oct 16th, 06, 10:34 AM
camaroman7d camaroman7d is offline
Royce
Default Re: How quick is your 2nd gen Camaro?
You'll go quicker with the 830 annular and you will love the throttle response. I sold my 70 but I went 11.90 @ 115mph 1.5x 60 fts on pump gas (91 octane) and street tires/ no nitrous. That was with 3.42 rear gears and a hyd. flat tappet cam. Dart Pro 1 heads, Victor jr. intake and the same 830 carb you just switched to. 385ci.
Royce (NO XQSSS) Bradley
Pictures
Sound Clip
(brief sound clip, 3" exhaust through Borla Sportsman mufflers)
"If you are not part of the solution, then you are part of the problem" Me
Old Oct 17th, 06, 02:02 AM
Silver Bullet
Wow -- that's impressive. What was the cam profile? Also, were your heads and intake ported? Concerning the 830 -- what jets were you running front and rear, and did you mill of the choke horn?
You're right I do like the 830. I *think* it's the list 9381 model iirc. The weird thing is, it had #86 jets front and rear stock, when I think it's supposed to have #78 jets front and rear. Maybe one of the Holley guys putting it together wasn't paying attention and put the wrong jets in.
Silver Bullet
1977 Z-28
Old Oct 17th, 06, 09:36 AM
Royce
I just ran out and looked at my old notes. My jetting was 76 primaries and 78 on the secondaries. Yes, the choke horn was removed. Cam was a Crower p/n 00245. 311/316 adv dur, .507/.524 lift, 112 LSA, 244/252 @ .050. My heades were bowl blended and smoothed out the exhaust port, I port matched the intake and heads.
About your jetting, I don't remember if my carb had a PV in the secondaries. If yours doesn't that could explain the larger jets (assuming mine did have a secondary PV). I sold that engine to a friend of mine and he put it in his Nova it still has the same carb and settings (I set it up for him). I could try to get him to pull the rear float bowl or see if he remembers if it has a secondary PV. He might not be willing to pull the float bowl, if he does that will probably lead to me working on his car.
Pictures
Sound Clip
Old Oct 17th, 06, 02:07 PM
Silver Bullet
Royce, thanks for the info. My 830 had 6.5 pv's front and back, 86 jets front and back, stock. I removed the rear pv and blocked it, jetting up 10 sizes to 96 which I think is too much. After about a 92 jet iirc the pv restriction has to be drilled to make use of a larger jet, but in any case I kind of thought it was weird to see such large jetting in stock form. I'm going to jet it way down, maybe go with 78 jets in the front (I replaced the 6.5 pv with a 4.5 pv because of idle vacuum with the big cam), and go with the stock 86 jets in the rear with the pv blocked. Or maybe I'll also block the front pv and re-install the stock 86 jets there as well. I'm thinking that maybe the Holley tech who built the carb mistakenly jetted mine like an HP830 (which comes with 86/86 jets) instead of the 9381.
That engine of yours worked pretty good -- what do you have in it now?
Silver Bullet
1977 Z-28
Old Oct 17th, 06, 03:47 PM
DirtyScotty DirtyScotty is offline
Tech Team
Scott
Havent been to the strip yet but I beat my friends stang 3 or 4 times now. He has gone 12.70s numerous times. So I must be a little quicker.
Old Oct 17th, 06, 04:03 PM
ZZ430DropTop67RS's Avatar
ZZ430DropTop67RS ZZ430DropTop67RS is offline
Don
Altitude corrected high 12s with a moderate 361 SB on street radials.
In other words, a slug-like high 13 up here.
Don ~ TC Member #15 Gold
Old Oct 18th, 06, 09:08 AM
Royce
No problem, hope it helped. I sold the Camaro the last engine in it was a 8-71 blown 388. I still have the engine and trans which is in my current project (1961 Buick Skylark) not running yet. Shooting for 9's on pump gas.
Pictures
Sound Clip
Old Oct 18th, 06, 06:46 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Team Member
Scott
Mine is quickly emptying my wallet.
Old Oct 19th, 06, 02:36 AM
Silver Bullet
Hehe -- I think we can all relate to that!
Silver Bullet
1977 Z-28
Old Oct 19th, 06, 02:38 AM
Silver Bullet
Whoa! That must have been an awesome powerhouse on the street! Get many races with that 8-71 sticking outa the hood?
Royce -- did you manage to get it to the track and get some times with that 388" blower engine while you still had the Camaro?
Silver Bullet
1977 Z-28
Old Oct 19th, 06, 02:40 AM
Silver Bullet
Beating the stangs is always a good day.
Nothing wrong with that, especially running way up in the rare air of the Rockies.
Silver Bullet
1977 Z-28
Old Oct 19th, 06, 10:37 AM
Royce
I never took it back to the track with the blower. To be honest it would have been a watse of time, there is no way it would have hooked. Roots blowers make so much low end torque it rediculous. This is the reason I started building my new project. I want to be able to hook all this power. No, not many people wanted to play with the blown engine. It was a lot of run to drive on the street but, if I ever really got on it, it just smoked the tires. Still should have gone easy 10's with lack of traction but, who knows. If I had it to do over I would have taken to the track just to see.
Pictures
Sound Clip
Old Dec 8th, 06, 08:13 PM
tkperformance tkperformance is offline
6.70 1/8 mile
1.45 60' time
it is a slapper bar car!
http://www.putfile.com/tntracing2
Old Dec 24th, 06, 07:54 PM
curtg21 curtg21 is offline
Curtis
My best so far is 12.41 at 107.5, 1.65 60'
355, stock heads, 9.75-1, vic jr intake, 650dp, 230 @ .050 w/.320 lift, th-350 w/3000 stall, 3.73 gears, pump gas, and N/A.
Oh yeah, its my daily driver
Similar Threads
why is it so expensive to restore?? RUSTY69 Bench Racing 54 May 1st, 07 12:04 PM
Carbon Fiber trunk lid 2nd gen camaro Dayton68Z28 Body Shop 1 Apr 6th, 06 05:54 PM
New Spal twin 12 inch fan kit 2nd gen Camaro alumitech Second Generation 0 Mar 31st, 06 05:17 AM
2nd Gen Camaro Wanted bowtie1Z28 Performance 2 Nov 24th, 05 11:33 PM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 07:53 PM
