Fourth Generation 1993-2002
Old Oct 16th, 06, 11:15 AM
rojo rojo is offline
Robert
Default P/S pump and steering rack ?
I replaced the steering rack and tie rod ends on my '94 V6 Camaro. Had it aligned and all seemed well for the first couple of days. I then noticed after driving a few miles at 60mph or so when I slowed down the P/S pump was growling. I headed on home and popped the hood to find the pump was extremley hot but the fluid looked fine, no bubbles, correct level. I decided the pump was just shot since it was original to the car so picked up a reman unit from NAPA. Put the new pump on and in a couple of days the same thing happens only this time the pump gets so hot it locks down and shreads the belt. Napa has me another on order but I'm beginning to suspect the rack. The steering is great until the pump starts growling. Can the rack be bad and still seem to be working fine.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
TC member #18
Similar Threads
Steering Column reassembly Steptoe Camaro Tech 17 Jan 23rd, 07 09:48 PM
P/S Pump Mounting Problems 68driver Brakes, Suspension & Steering 4 Jul 29th, 05 09:14 PM
Correct power steering pump and pulley for 69 Z28 jlighthart Engine 0 Nov 15th, 04 03:52 AM
Front end kit in Canada Mark Yetman Brakes, Suspension & Steering 19 Mar 14th, 04 02:27 PM
Power Steering / Belt Alignment Problem kgaffney Tech 2000 17 Jul 9th, 01 05:36 PM
