| Team Camaro Tech Current Topic: Garage find, what's it worth? | ||
| What's it worth? & ebay discussions |
I found a replacement 302 engine while cleaning part of my garage and just want some opinions on what it might be worth.
casting number = 3970014 cast date = F-29-72 deck stamp = CEA2214 It has 1178 crank/L-2210A STD pistons/"O"rods/7173 balancer with 360 dgree timing marks. It also has a set of L-2209A pistons that the previous owner removed when the L-2210A's were installed. It also has the windage tray and oil pan. Bore has no ridge and the L-2209A pistons don't have any scuffs on the skirts. I opened the other boxes and found the heads = #186 dated G-21/24-9. Thanks in advance for you help. Eric |
http://www.mortec.com/castnum.htm Do you have a pic of the crankshaft flange?
Rob SIM Member Nov 08 Nov 68 69 Z-28 X-77 HO * DZ Put away * 406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200* CC 1.52 Pro Mag RR* Perf Air Gap * Eagle 4340 Crank/Rods * Sep 07 -12.68 @ 113 1/4 * Oct 08 116.2 MPH |
It is a 302.
Service replacement engines use the block casting/revision that is in production at the time the engine was assembled. I give the example of my friends 69 Vette. The original engine was a #512 casting. When he grenaded the engine, it was replaced with a #289 casting at the dealership. The #289 was never originally used for 427 engines. Thanks for the input. Eric |
Just how big is your garage?
Rod 69 Camaro - 355 SBC, 2004R, 12 bolt posi w/ 3.73, Baer 4WDBs w/ Hydraboost, Hotchkis & GW susp, Budnik Cobalts, Marquez Design pieces, DSE dash & Billet hood hinges, Corbeau TRS seats... Smoothing firewall and Upper dash panel replacement |
Rod,
At one time I had 8 camaros plus parts in it, many years ago. As I sold them off, I filled the spaces up with parts. Now I am just tired of having to move something to walk thru it. Last month I had to move fifteen 12-bolt rears to find a BT coded one for a friends Nova. I still haven't found the L-79 engine that I started looking for. Anyone got an idea of what that 302 engine might be worth? Thanks again, Eric |
Well first off, your market/end user is likely someone who has an X33, X77 or LA built Z28 without it's original 302, or someone that wants a serious Z28 clone. The drawback is it being a CE block, with no manifolds, carb & pistions, etc., I would guesstimate it's value at $1,500. Charlie
I volunteer to help clean out the garage
I will take a 12 bolt off your hands, It will be one less to move or step over.
69 Camaro RS 396bbc |
Well since your giving stuff away, I'll take the block and crank off your hands so you no longer have to trip over it.
#11
The block being a CE block dated 1972, I don't thing it is worth any more than any other 1972 350 block. The value of the actual 302 parts would depend on the condition of those parts. JMHO
Russ '67 4 speed coupe '67 rs coupe '94 6 speed z-28 '51 Chevy pickup |
#12
8 car garage
8 Camaros Filled with parts Found a LOST 302 Any chance you have a friend called FireBall2? Remember the kid who called wolf! Now I can't trust anything I read
67 Camaro RS350SS (already restored) 68Convertible(future project) 68 Coupe(restoring)On hold ![]() 67 Convertible (restoring) ![]() 67 Coupe(parts car for now) ![]() 72 Chevelle Malibu 69 Jaguar xke roadster(appeasing the wife) |
#13
Thank you guesstimate Charlie. I will use you estimate as a reserve. I will list it with a pair of 4295's and see what does.
And thanks to everyone else who offered to help clean. A FireBall2 is a Crane camshaft as far as I know. And everyone knows there aren't any wolves around here. The 8 car is the detached garage, (the house has a 4 car attached). I had 8 camaros before I got married, and sold them one by one. A wife and kids are exspensive. The only cars I have left are two camaros (a Z10 and a RS/COPO), a 1960 283/270 Vette, and a 1938 Chevy Sedan. Thanks again, Eric |
#14
Eric toss some pics of your 2 camaros in here. love to see the Z10 and know more about its options and numbers too
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto. "There will come a time when you believe everything is finished, That will be the beginning." Louis L'Amour Our Camaro Webpage Photos for viewing Learn How To Post Pics here |
Similar Threads
| Is it worth doing? | fdny37 | Restoration Corner | 6 | Jan 1st, 06 08:23 PM |
| garage door opener?? | JimM | Electrical & Wiring | 10 | Dec 28th, 05 09:28 AM |
| Garage Lighting | Silver69Camaro | Bench Racing | 13 | Dec 23rd, 05 07:52 PM |
| Garage Heater | 67FamilyFun | Bench Racing | 39 | Dec 15th, 05 06:46 PM |
| Cant find owner to 67 vert | blue ss | Bench Racing | 0 | Jul 26th, 05 08:17 AM |
