Third Generation 1982-1992
Old Oct 18th, 06, 10:06 PM
87iroc355zz4 87iroc355zz4 is offline
Chris
Default Need help ,my car idles high when ever it wants
If i disconnect the electronic advance it drops down to a constant idle.Once i plug it in it idles higher constanly at a certain rpm ,thats too high for me.Then i put the car in neutral and tap the gas then it drops back down for a little while. What controls the idle control valve? It seems to be idleing up when ever it wants.Its been doing this long before i built my engine.
Old Oct 19th, 06, 04:57 AM
Everett#2390's Avatar
Everett#2390 Everett#2390 is online now
Drive a '68!
Default Re: Need help ,my car idles high when ever it wants
ECM controls the IAC (Idle Air Control), a controlled vacuum leak. Bigger hole, higher rpm.
Your idle characteristics are dependent upon the camshaft specs. ECM-controlled engines demand short duration@.050 and a wide lobe separation angle to bring in a high vacuum value. Typically, 220*@050" lift & min of 114* LSA are the minumum of stock specs for a stock chip, I believe.
The ECM is correcting this low vacuum signal, from the MAP sensor, by increasing timing and bypassing more air via IAC, to bring up the vacuum, hence higher rpm.
The above assumes you have a TPI intake system and being an 87, no MAF sensor, and a ZZ4 camshaft.
These are just my thoughts, I could be out in left field...........
Give a man a rescue dog for the health of his soul.
My 68 Camaro http://www.flickr.com/photos/everettwn68
Old Oct 19th, 06, 08:04 AM
JimM JimM is offline
Jim
Sometimes IAC valves get gummed up. Pull it out and clean the part that sticks into the throttle body as best you can. My experience has been that once this starts to happen, cleaning will fix it, for a while, but the problem will come back in a month or two.
fyi, the IAC is a can, about an inch in diameter and an inch long, located on the throttle body.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Old Oct 19th, 06, 08:30 PM
Chris
I just installed a brand new iac valve and i took the throttle bodie apart and cleaned it but still have the same problem.Ive had the idle problem for years.
Old Oct 19th, 06, 08:37 PM
Chris
I have a l98 tpi 355 with a zz4 cam ,aluminum corvette heads,flat top with 2 reliefs ,it has a MAF on it.I had the same problem before i built the new engine. Now its more obvious because of the new engine. Do you think it might be the computer? or vacume leak some where?
Old Oct 19th, 06, 08:55 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is online now
Team Member
Scott
Is it throwing codes?
Vac leak comes to mind.
Old Oct 20th, 06, 05:20 AM
Drive a '68!
As Bonzo suggests, it could be a vacuum leak. Since you have TPI, the EGR valve underneath the plenum could be leaking, giving a vacuum leak, if the valve is installed, usually removed by owners.
Having a MAF sensor does help your combo, they are more forgiving towards engine mods. Does the engine quit running when you place your hand over the intake opening? Is the tubing/intake runners/plenum between the MAF & throttle body in good repair, meaning no leaks/cuts/holes?
You might try to reset/check the base settings of ignition timing and base rpm. Bring engine up to operating temp. Turn off engine and ign. Short ALDL Pins A to B, turn on ign, no start for 10 seconds. Turn off ign. Disconnect IAC connector and place igniton system into bypass by unplugging a brown wire either at passenger firewall or by the pass kick panel and remove the short between Pins A & B. The ECM has seated the IAC, bypassing the ign system takes out ECM control of advance.
Start engine, base rpm, on a stock camshaft V8 would be around 600-700 rpm. Timing would be around 6*-10* BTDC. See what vacuum gauge reads at this time. A stock engine reading would be 18-20 in./Hg. Yours with a ZZ4 cam, or vacuum leak, may be around 15-17 in./Hg., I'm only guessing. Adjust for best vacuum reading, the higher, the better.
Connect everything back up, disconnect the battery to erase codes from ignition bypass, and hopefully, the engine will rpm correctly. Read vacuum gauge, the ECM is looking for 18-20 in./Hg. If not there, then ECM is correcting rpm to read 18-20 in./Hg.
You might try the trick of using a Mity-Vac hand vacuum pump on the MAP sensor and see if this helps. If it does, then you need a reprogram.
Old Dec 4th, 06, 10:06 AM
Buddy_Lee Buddy_Lee is offline
Tech Team
Buddy.......literally
my dads mustang did the same thing and he cleaned out the thottle body and problem solved
Similar Threads
1968 Yenko Camaro YS 8011 unlodged 427Freak Copo & Dealer 25 Jun 13th, 06 05:04 PM
Idles very high Samuel Engine 4 Jul 5th, 04 06:56 AM
Q-jet idles HIGH in neutral and then lowers in gear? 1968camaro123 Engine 6 Jan 8th, 02 03:53 PM
