Fourth Generation 1993-2002
Old Oct 19th, 06, 11:34 AM
scoobydoo scoobydoo is offline
Default 2001 V6 overheating
I can get a 2001 V6 camaro convertable with just over 120K miles for $3500
the car is in "good" shape with a nice interior and top.
BUT even though it seems to run good, it will not pass emissions. And now has a overheating problem.
The owner has replaced the radiator, and thermostate but the car still overheats.
He now swears it must be the waterpump ($50)
But I am very sceptical because the pump does not leak, every failed waterpump I have ever seen leeked out the weep oil.
I am thinking maybe the fan is not coming on ?
or maybe a bad sensor somewhere ?
Is there something that generally goes bad with these engines that casues this overheating ??????
NEED HELP ASAP as I think the car will sell FAST at this price
Old Oct 19th, 06, 06:03 PM
Bowtie68 Bowtie68 is offline
Lee
Default Re: 2001 V6 overheating
Is your SES light coming on. I think usually in these engines if the fan doest come on when its suppose to or there is a bad sensor the computer should though a code. If so just borrow a OBDII scanner from Autozone and scan the PCM.
1968 Camaro with a 383 finally done and on the road!
Similar Threads
2001 Camaro Coupe Audio System? HCHS_Tenor Interiors 1 Nov 3rd, 08 11:08 PM
Bummer...STILL Overheating.....HELP ! markr Heating & Cooling 37 Oct 24th, 06 12:07 PM
front turn signal bulb replacement in a 2001 camaro tantu Troubleshooting 0 Dec 27th, 05 10:46 AM
Intermittant Overheating thboadway Troubleshooting 1 Jul 17th, 05 07:55 PM
86 Z28 Overheating Magicmile24 Heating & Cooling 2 Jun 12th, 05 07:10 AM
