Third Generation 1982-1992
Old Oct 21st, 06, 12:14 PM
david anderson david anderson is offline
Red face Electrical Problem
I have an 85 that I bought for a 16 year old. Didn't pay much.
I'm having an electrical problem where no power goes from the battery to the rest of the car. The car was working fine. I can't find anything obvious. Where do I start.
What book is the best -- I've got a chilton's
Old Oct 23rd, 06, 09:37 AM
Troy Adam Troy Adam is offline
Troy
Default Re: Electrical Problem
Is everything dead? Head lights, dome light, radio etc... or just your ignition system? Also, have you checked the battery and cables for corrosion.
Troy Adam
Old Oct 23rd, 06, 10:27 AM
JimM JimM is offline
Jim
85 would be hei and carb. They use the big post on the starter (where the battery cable goes) for power distribution. There will be a number of 12 guage red wires connected there depending on the options on the car. Most of them arew fusible links. These often get "messy" with years. Check em out. The only other wire on the starter is the "crank" wire, usually purple, to the inside small stud.
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
Similar Threads
In Need Of Major Help!! Please!! Justgotacamaro Engine 31 Mar 6th, 07 06:22 AM
Air Conditioning Problem Mark C Heating & Cooling 21 Jul 17th, 05 11:16 AM
Help, electrical problem mk69camaro Electrical & Wiring 4 Feb 12th, 05 06:47 PM
Electrical problem Truckinfree Electrical & Wiring 1 Mar 30th, 02 01:11 PM
Mysterious electrical problem with 69Z hbrucker Troubleshooting 4 Jun 28th, 00 05:44 PM
