Fourth Generation 1993-2002
Old Oct 22nd, 06, 07:16 PM
mike68camaro mike68camaro is offline
Tech Team
Mike
Default replacing dashpad on '97 camaro
my girlfriend has a '97 camaro and the dashpad has a crack going right through the middle of it. is there anywhere besides the dealer that these are available? how hard are they to replace?
Old Oct 22nd, 06, 09:51 PM
Bowtie68 Bowtie68 is online now
Lee
Default Re: replacing dashpad on '97 camaro
Junkyards. Depends where you are located. Out here in California we have a place called GM Sports Salvage. They buy up a lot of wrecked f-bodys and you can find some good stuff there cheaper then the dealer asks fot it. They dont allow people to walk around and take their own stuff off either so there are better chances that more parts arent as damaged as the pick in pull where people just bust off anything in their way of the part they need.
Anyways just advice to look around and see what your options are. There is always ebay too.
1968 Camaro with a 383 finally done and on the road!
Old Nov 1st, 06, 07:26 PM
Tech Team
Mike
anyone have any suggestions on changing these?
Old Nov 27th, 06, 08:17 PM
shootin4over200mph shootin4over200mph is offline
Greg Pannell
Changing the dash from factory to factory isn't that bad, but if you get a earlier year dash, it will be a headache. Be sure to get an identical dash. I swapped a 95 dash into a 97 and it was almost not worth the trouble. the 95 has a driver wrap around dash were as the 97 has a straight dash. The wrap arounds look alot better, but the instrument clusters are not the same, and require you to change the connectors on the wiring harness. The top panel of the dash simple pops off, the remainder is bolted on along the top, and underneath.
Similar Threads
Considering selling my Camaro Hrod382 Bench Racing 20 Feb 1st, 06 06:15 PM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 07:53 PM
replacing rear hatch glass on 86 camaro rrmorris67 Body Shop 4 Aug 7th, 05 01:25 PM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 08:27 PM
Finding the good 69 Camaro. hemi.42 Tag Team 2 Jul 6th, 04 07:40 AM
