| Team Camaro Tech Current Topic: Which Cam do you recomend???? | ||
Wanting to go Solid or Hydraulic lifter from roller. Strictly Drag Race, 1/8th mile heres the specs....
1969 Camaro 406 12:1 (Never acutally checked) Iron Eagle 215cc 205/160's 4.33 gear 12 bolt 400 turbo TransBrake 3800-4000 Stall Approx. 3500lbs 28 tall tires Air Gap Intake 750 DP "OLD CAM" Doug Herbert Solid Roller 285-285 .555/.555 (.244/.244 @.050) 60 ft. 1.52 330 4.78 1/8th ET. 7.50's MPH 88 LEt me know what you think. Reason for changing, Motor Blew to the moon. I know its not the cams fault, I just wanna turn around 5500-6000 RPM Dont really think there is a need for a roller. Thanks!
Eric Bowling 2008 Ohio Crankshaft No Box Nationals Winner 1969 Camaro 406 sbc Edelbrock Performer RPM Aluminum Heads 400 turbo 5600 8 inch Coan Converter Transbrake 4.56 12 bolt 750 Holley RaceonE85.com Carb |
| Sponsored Links | ||
Advertisement | ||
I run Lunati's Voodoo 60105 and I'm very happy with it.
Basic Operating RPM Range:2,500-6,500 RPMIntake Duration at 050 inch Lift:241Exhaust Duration at 050 inch Lift:249Duration at 050 inch Lift:241 int./249 exh.Advertised Intake Duration:284Advertised Exhaust Duration:292Advertised Duration:284 int./292 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.525 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.546 in.Valve Lift with Factory Rocker Arm Ratio:0.525 int./0.546 exh. liftLobe Separation (degrees):110 If your only going to pull 6k this may be a bit big, because it really starts to pull on my motor at @5k, and goes strong to 7k+. Although I do run 1.6 rockers. You may want to go one step down to the 60104.Basic Operating RPM Range:2,200-6,400 RPMIntake Duration at 050 inch Lift:233Exhaust Duration at 050 inch Lift:241Duration at 050 inch Lift:233 int./241 exh.Advertised Intake Duration:276Advertised Exhaust Duration:284Advertised Duration:276 int./284 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.504 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.525 in.Valve Lift with Factory Rocker Arm Ratio:0.504 int./0.525 exh. liftLobe Separation (degrees):110 Or my old cam. Comp Extreme XE284H Basic Operating RPM Range:2,300-6,500 RPMIntake Duration at 050 inch Lift:240Exhaust Duration at 050 inch Lift:246Duration at 050 inch Lift:240 int./246 exh.Advertised Intake Duration:284Advertised Exhaust Duration:296Advertised Duration:284 int./296 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.507 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.510 in.Valve Lift with Factory Rocker Arm Ratio:0.507 int./0.510 exh. liftLobe Separation (degrees):110
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss We learn life's important lessons in kindergarten. Harley D '67 coupe 427SBC 60'1.728 1/4-11.83@115.59firstgens.com |
Well if you ARE running 12:1 you dont want to go smaller i wouldnt think. I run an erson 296/302, 258/264@.050 .562/.562 on a 108 that would probably work well, but youre going to spin 6,800. Its a solid F/T. It would work well with your large heads but youde need a single plain intake and maybe a bit more stall to take advantage of it i would think.
73' Nova, 350, Richmond 5 speed, Ford 9", Making some changes.... Best ET 11.88 MPH 116.05 60' 1.67 http://s239.photobucket.com/albums/ff152/novaguy73/ |
for a roller i would use the herbert c6g.you can see what my nova runs on the signature,almost the same combo as yours .i do shift at 6200 though.for a solid that runs as good i would use a elgin or herbert 556 533 lift 264 256 at 50 thousands.that cam runs as good as the roller,at the rpms i turn.use a 106 center line and small base circle.i ran the elgin cam in a 383 and a 400 and it worked very well.the best it ran in my chevelle was 7.40s with the 383 and it ran a 7.12 with 406 .sold the 383 to a buddy with a camaro and he ran a best 7.07 i believe.and thats with a set of 186 casting heads
67 NOVA 406 best 6.789 in 1/8th 1.437 60ft at 99.26 mph 66 chevelle 406 best 7.12 in 1/8th |
The pistons I am using states 12.08:1 with a 64 chambered head, so that is what I am basing comp ratio to.
http://www.empirenet.com/pkelley2/DynamicCR.html then use the DCR to calculate your compression. You'll need to know all of your specifics, heads (have they been shaved?), head gaskets, pistons (dome or dish volume), bore, stroke, etc.
Steve 1968 Coupe., filled with cool stuff from Tremec, Moser, Ron Davis, Speedtech, ATS, Hotchkis, Forgeline... blah blah blah Check it Out Here |
Lunati 401A6LUN solid flat tappet
Advertised Duration IN/EX: 276/284 Duration @.050 IN/EX: 243/251 Gross Valve Lift IN/EX: .518"/.530" Lobe Sep Angle / Intake Ctr Line: 110/104 very popular cam with 406 chevelle guys, so plenty of info on performance. will be right arounk 6k shift. search cam on chevelles.net if you want to hear more from users |
| Sponsored Links | |
Advertisement | |
Similar Threads
| overlap, and stock idle | L79Mike | Performance | 13 | Jan 21st, 06 09:23 PM |
| roller cam ? | l1tech | Performance | 12 | Jan 12th, 06 06:52 PM |
| intake and cam questions | importkiller69ss | Performance | 17 | Dec 6th, 05 08:39 PM |
| Want new heads and or cam | DenRS | Performance | 19 | Nov 20th, 05 09:57 AM |
| "setting" cam end play | nitrous383 | Engine | 21 | May 13th, 05 06:07 AM |
