Pro Touring Todays performance with classic style
Old Oct 24th, 06, 04:26 PM
ace's68 ace's68 is offline
john
Default pro touring question
thinking of going pro touring and mainly pro touring is road racing instead of drag racing, would a 383 be a good idea for a pro touring car for the occasional road racing? or should i go with a smaller stroke 377 de-stroker or 302 to maintain rpms through the corners?
The only Mustang I'd ever own is a Fender.
Old Oct 24th, 06, 04:35 PM
baz67 baz67 is offline
Default Re: pro touring question
A 383 is fine, IMO. FWIW, I am putting a LS2 402 in my PT 67.
Old Oct 24th, 06, 04:55 PM
1stgenCR 1stgenCR is offline
Cubes are less of an issue as much as how the engine is built and makes power.
68 Camaro frame off project. Hotchkis suspension (springs, sway bar, shocks), EFI 350, T56 6 speed, 8.5" 10 bolt posi with Tom's axles. 4 wheel disc brakes.
Check out pics at http://www.cardomain.com/ride/2334689/1
Old Oct 24th, 06, 06:45 PM
john
ya, in my opinion its mainly all in the stroke. i know of someone with a blown 383 which makes its peak h.p. @7,300rpm which is sorta what i want to do but maybe in the 6,500rpm+ range, it would be nice to have big cubes and a high reving motor with a rather large stroke.
Old Oct 24th, 06, 07:59 PM
JV69z/28rs JV69z/28rs is offline
For what it's worth NO ONE knows more about auto crossing/road racing 1st Gen Camaors than one of our moderators David Pozzi. He chose a GM crate 383/425 motor for his wife's car. That would be the only reason I would need to make up my mind. I don't think you could go wrong with that type of combo in your ride. Good luck with whatever you decide.
Jack
ProdigyCustoms ProdigyCustoms is offline
Frank
The 377 would be more fun in a lighter car. but in a full weight car I like the torque from the stroke. however, if you had the block to build the 377, a 406 would be my choice
Frank Serafine
Prodigy Customs
Pro Touring Muscle Car Specialist
FREE PRO TOURING TECH and PROJECT PLANNING for Forum Members
Weekdays 8AM TO 10PM EASTERN TIME
FOUR ZERO SEVEN 832 1752
GP SuperStore
Group Purchase Discount Auto Parts
Old Oct 24th, 06, 08:25 PM
CarlC CarlC is offline
Yup, because driving the line is more important than the right foot.
Carl's Camaro
Similar Threads
Camaro goes redneck! plus a question..? maxharvard Performance 15 Jul 29th, 06 08:52 PM
Pro Touring using CE weld in Frame conn and formed rails Leadfoot1 Brakes, Suspension & Steering 15 Oct 10th, 05 09:03 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 07:08 PM
