right pistons - Team Camaro Tech
Old Oct 24th, 06, 08:12 PM
427tall 427tall is offline
Default right pistons
I have a 427 tall block, going to put a 4.250 stroke crank .060 over and 6.535 rods, do i have to use pistons that match the stroke and rod lenght or can i use any piston as log as the compression height fits?
thanks
Old Oct 25th, 06, 05:36 PM
Rogers Performance Rogers Performance is offline
Mike Rogers
Default Re: right pistons
You need to cal. the compression height.
Mike
Automotive Machine Shop
Racing . Stock . Antique
Complete Engine Rebuilding
215-674-5240
www.rogersperformance.com
rogersperformance@msn.com
Old Oct 25th, 06, 06:58 PM
pdq67 pdq67 is offline
Banned
Question Re: right pistons
10.200" - .025" - 2.125" - 6.535" = 1.515" compression height!
Right Mike??
pdq67
Old Oct 26th, 06, 04:44 PM
Ya, i did all that fun math to figure out the comp height, ended up calling Competion Products and they said i had to buy pistons that fit the stroke and rod lenght, couldn't just use a pistion that fit the comp height, it had to be fore a 4.250 stroke and 6.535 rod, thanks
Old Oct 26th, 06, 05:45 PM
GOSFAST GOSFAST is offline
That's a very popular combination out our way built with a 10.180" deck. Shouldn't be any reason you can't make an easy build without custom ordering any parts. Thanks, Gary in N.Y.
P.S. If you checked it all out you should be around a 1.520 C.H. These are stocking pistons among many builders. You'll get about a 10:1 C.R. with a standard 118 cc BB head and the +.400 rods!
Old Oct 26th, 06, 05:52 PM
Larger Dave Larger Dave is offline
Dave
Compression height gets the piston to the top of the bore (which is a good thing) but it has to match the stroke and rods also because other wise the crankshaft counter weights will pass through your piston skirts (that's a bad thing). So both answers are correct.
Larger Dave
Similar Threads
Pistons ace's68 Engine 5 Aug 4th, 06 03:50 PM
Prep tips for experienced 2nd timer - installing hi-dome forged pistons caribbean camaro Performance 8 Feb 1st, 06 07:24 AM
Removing domed pistons? Silver69Camaro Performance 18 Jan 14th, 04 02:16 AM
AFRs with dome pistons? 1FASTZ Performance 0 Feb 19th, 03 11:58 AM
Gonna get pistons, but hit obstacle BreathWeapon Tech 2002 5 May 30th, 02 12:07 AM
