Bug Hunt Computer related problems
Virus warnings - Technical help.
Old Oct 26th, 06, 10:50 AM
Codi's Avatar
Codi Codi is offline
Jim
Exclamation Dowload Photo Story slideshows to CD's
LB has a project due next week at school. He has decided to create a slideshow in Photo Story 3 but we have no way of copying it to a CD or DVD so it will play on a TV screen at school. Anyone have ideas on software that will create the CD or DVD with the slideshow? I am totally lost here as my knowledge stops at the on/off switch. My understanding is we need software that will format the CD or DVD for play in a DVD player and with this we can download his slideshow to the CD/DVD. I have checked some of the stuff mentioned in other posts but found nothing that will do what I need to do.
Daddy's Hot Rod.
http://www.camaros.net/showroom/show...e=365&way=desc
Old Oct 26th, 06, 11:00 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Re: Dowload Photo Story slideshows to CD's
I use Photo story and you can drop the whole program on a memory stick that plugs into your USB. If the school will let you use a PC to play the memory stick and project that onto a larger screen, it will work. If you MUST use the CD/DVD then dump the program onto a memory stick and take it to someone elses house that has a DVD burner and they can pull it from the stick onto a DVD.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto.
Our Camaro Webpage
Photos for viewing
Learn How To Post Pics here
Old Oct 30th, 06, 10:24 AM
Codi's Avatar
Jim
Thanks Click. I contacted Microsoft for advice. They recommended a "plug-in" from Sonic. I need to develop a slde show in Photostory and burn a CD/DVD so LB can take his project to school for a presentation. Sonic has a plugin for Photostory. I used it this weekend and after several hours finally got a DVD to burn. Once I play with it a bit more i will figure out the right and wrong moves.
Daddy's Hot Rod.
Similar Threads
Ok here's a twist on recording cd's click Bug Hunt 17 Aug 22nd, 06 07:50 PM
Mister G's Photo Story NeoValentine Bench Racing 9 Jan 18th, 06 10:02 AM
