| Team Camaro Tech Current Topic: Lowering question | ||
| Fourth Generation 1993-2002 |
Hey guys, I just bought a 99 camaro ss, I am getting 18" rims with 275/40 all around, what do you recommend for: springs, and how much of a drop.
1 inch lowering springs from eibach will put it at a great height. Also, get some revalved bilsteins (do a search on www.cz28.com, the revalved bilsteins are made for lowered rides). This combo will not only make your ride decent, it will make it handle awesome and look good while doing it.
do you have pics of your SS?
I had 18'' wheels on my 01 SS....I had the REALLY low Eibach kit, Sportline I believe it was called....sat low but sexy!
'67 Camaro in the works... |
so this is just a matter of swapping out the stock springs for the eibach lowering springs? that's it? i also have a '99 z28 and would be interested in lowering it a bit.
bill 1969 Camaro RS Convertible, 350/350 turbo, chevelle front disc brakes, nova 8.5 10 bolt rear w/ 3.73 posi 1999 Camaro Z28 m6 2001 Suburban 1500 1952 Chevy Pickup, 350/350 turbo, nova front clip w/disc brakes |
In my opinion if you are going to lower the car, make sure to buy shocks that are built for that ride height. Stock 4th gen shocks are not that great. There are bilsteins that a guy revalves over on www.cz28.com. They are perfect and will give you enhanced ride quality with the look.
I dropped mine an inch and a half with eibach springs. Any lower and speed bumps will be greeting you with sparks.
95 z28 |
i heard that eibach sportlines are a good look but not very smooth of a ride..you should go with hotchiks for springs. They give about a 1" drop but they are a bit expensive. And for shocks you cant go wrong with KYB AGX
Similar Threads
| Lowering question | cotomoto00 | Fourth Generation | 2 | Oct 30th, 06 06:06 AM |
| lowering compression from 12.5:1 to run 91? | DWG | Performance | 49 | Sep 15th, 06 11:49 AM |
| Second generation 70 Z28 question | nikkisdad | Second Generation | 15 | Feb 4th, 06 11:40 PM |
| Lowering block question | choptop | Brakes, Suspension & Steering | 15 | Sep 18th, 02 01:45 PM |
