Difference between 8.2 and 8.5 differential - Team Camaro Tech
Thread Tools Display Modes
Old Oct 30th, 06, 12:48 PM
within1sreach within1sreach is offline
Tech Team
Default Difference between 8.2 and 8.5 differential
How can I tell which is which,I've done a search and noting that says what to look for.Any help would be great.Thanks guys...
Old Oct 30th, 06, 01:18 PM
Lucky68's Avatar
Lucky68 Lucky68 is offline
Mike
Default Re: Difference between 8.2 and 8.5 differential
Check out the link below. There's a ton of differential information.
They're pretty easy to tell apart, the 8.5 rear has the square lugs that are visible on the bottom corners of the pumpkin where the 8.2 has none. The 8.2 would be a factory 1st Gen 10 bolt and the 8.5 would have most likely come from a Nova.
http://http://www.novaresource.org/axle.htm
1968 Camaro Coupe: Forged 383, AFR heads, Edelbrock Air-Gap intake, Holley 750 dp, Dynatech headers (557 HP/543 TQ), TKO-600, 12 Bolt 3.73, Vintage Air.
http://rides.webshots.com/album/250023748XWhfQW
Old Oct 30th, 06, 03:13 PM
Tech Team
Thanks, that's just what I was looking for.
Old Oct 30th, 06, 05:08 PM
1stgenCR 1stgenCR is offline
Cool. Always assumed I had the 8.2" 10 bolt in my 68 Camaro but just checked using the identification info in the link and I have the 8.5"
68 Camaro - TCI subframe & 12 bolt torque arm, Ridetech triple adjustable shocks, 427" LS3, T56, Wilwood brakes
Videos of Camaro in action on road course / track days.
https://www.youtube.com/TheDude023
Old Oct 31st, 06, 07:50 AM
elcamino72 elcamino72 is offline
Bryan Shook
8.5's from some Novas can be made to fit right under a 1st gen, that's most likely where yours came from ... the 8.5's are considered stronger than the 8.2's ... also there seem to be more gear choices availible for the 8.5 as they were install in vehicles up through 2000 or so.
Bryan Shook
Collector Car Lawyer
Old Oct 31st, 06, 09:17 AM
Lucky68's Avatar
Mike
72-75 Nova 8.5 rearends are direct bolt in for 67-89 Camaros. I've heard that the driveline may need to be shortened though.
Old Oct 31st, 06, 09:28 AM
madmax87's Avatar
madmax87 madmax87 is offline
Here's a pic of an 8.5, 3:73 posi under my 69 Camaro. Direct bolt in. Great diff and alot less than a 12 bolt.
Here's a pic of a 8.2. The diff cover is an easy way to tell the difference too.
Dennis
69 Z/28. 302DZ, Autogear M22, Red w/black stripes.
69 Camaro, ZZ4, 700R4, 8.5 3:42 posi, X11
70 Nova SS 396, 4sp, 3:55 12 bolt
Old Nov 1st, 06, 02:10 PM
zzzzz zzzzz is offline
Tech Team
Jim Mitschke
Please do not go by diff covers ...Those are interchangable they will bolt on to either housing. The casting is the only true way to tell. Look at the first picture 7 and 5 o'clock bolts. See the 8.5 casting triangles...That is on all 8.5 rear even up till now 2000 etc. May look abit different but will all have extra casting flashing that hangs out like that. Also if you look at the casting collar where both axles are press into the center section will have (4) equally spaced bumps too All of them 1973 1980 GN 1996 Impala and all the 10 bolt 8.5 trucks will have these casting similiars. The Yokes will all have 4 bolts and 2 straps system to hold in the u-joint. If it has u bolt to hold the u -joint in it is NOT a 8.5 for sure. ope this extra info helps. Jim J D RACE.COM
J D RACE AND RESTORATION
GM Differential specialists
Richfield, Oh
www.JDRACE.com
Old Nov 1st, 06, 02:20 PM
Z06vette Z06vette is offline
Scott
zzzzz are the yokes interchangeable? I just got a rear end and found the driveshaft is now about 1/2" too long. I determined I got an 8.5 rear end by the yoke, and the triangles. What I thought was a good deal turns out to be a great deal. I can always have the driveshaft shortened but I was just curious. Scott
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Old Nov 1st, 06, 03:51 PM
DZ Fool DZ Fool is offline
Danny
3"
69 Rally Sport-Z/28-Orange/Wht stripes-White vinyl-Ivory Houndstooth Interior Fold down seat Early 69 ( 11/12/68) 5494xx vin
67 RS Coming Soon
http://www.chitownracing.com/forums/...572a4a5071.jpg
http://www.myspace.com/danny_db
  #11
Old Nov 1st, 06, 05:50 PM
big gear head big gear head is offline
Freddie
The 8.2 yoke will not fit the 8.5. The 8.2 has a 25 spline pinion and the 8.5 has a 30 spline pinion. If you get a yoke from a '71 to '75 8.5 rear end it will have the 1310 u joint and your drive shaft should work without modifications.
  #12
Old Nov 3rd, 06, 02:38 PM
JOE58 JOE58 is offline
Here is a picture of a mult leaf 10 bolt from a 69 Camaro that I thought is a 8.5 but it has the u bolts to hold the u -joint. It has the larger size bolt heads to hold ring gear and looks like it has triangles. gear ratio is about 3.55
Is this a 8.5?
thanks
  #13
Old Nov 3rd, 06, 05:26 PM
Freddie
Can't tell from this angle. Can you post a picture from the other side? If it has 3/4 inch heads on the ring gear bolts and a 1 1/4 inch pinion nut then it should be the 8.5.
  #14
Old Nov 4th, 06, 03:01 PM
thanks for the reply big GH
here is another picture. I think its a 8.5 but it has the u bolt on u joint not the strap/bolts on u joint.
  #15
Old Nov 4th, 06, 04:47 PM
Freddie
That's a BOP 8.2 10 bolt. It has no c clips and is a little stronger than the Chevy 8.2, but it isn't an 8.5.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: Difference between 8.2 and 8.5 differential
Location
Location
First Name
Human Verification
Similar Threads
Stock 69 10 bolt -8.2 or 8.5? jrager Transmission & Driveline 3 Apr 13th, 06 07:42 PM
10-Bolt 8.2 vs 8.5 RPOZ11 Transmission & Driveline 3 Jan 31st, 06 04:18 PM
Swap 8.2 to 8.5 turbosix Brakes, Suspension & Steering 5 Aug 16th, 05 06:13 AM
8.2 or 8.5? bgreen63366 Tag Team 2 May 25th, 05 05:50 AM
8.2 or 8.5? bgreen63366 Transmission & Driveline 2 May 23rd, 05 10:02 PM
