Window Trim Removal - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Nov 2nd, 06, 12:37 PM
Hackman Hackman is offline
Default Window Trim Removal
Any advice on how to remove the front and rear window trim on a 69 Camaro? Also, does the rain gutter trim just snap off?
Thanks for your help!
Old Nov 2nd, 06, 12:46 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Default Re: Window Trim Removal
The front and back glass is held on with clips. They sell a tool that slides under the chrome ( from the window side ) and catches these clips. It actaully grabs the clip and when you turn the tool it unlatches from the chrome. Go to a Auto Parts store and ask for the tool. They make a couple of different designs. The bottom front window chrome is bolted on. One small screw in the door jambs and when you remove your valance panel you will see the other screws.
I have heard of using the old style bottle openers to get the side chrome off with. Just use it like taking the bottle cap off. It is a real pain to get off with out damaging it. Just take your time and be gentle.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old Nov 2nd, 06, 01:07 PM
chuck69ss's Avatar
chuck69ss chuck69ss is offline
Chuck
Try searching the database if you need more info. I read many many posts about the rain gutter moulding and I'm planning to leave it in place rather than risk damaging it. I had to remove the front section only due to some rust.
Chuck B
RI
69 SS Clone (from SS Donor car) - Frost Grn, x11, 350 4bbl, COMPCam XE256H, Crane XR-i HEI, M20, posi, Flowmaster 2.5";
'68 GMC C1500, Photo albums
You can live in your car, but you can't drive your house.
Old Nov 2nd, 06, 01:57 PM
Chuck/Mike, thanks for your quick replies, much appreciated!
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Window Trim Removal
Location
Location
First Name
Human Verification
Similar Threads
"Basics of Basics" Window Setting MARTINSR Body Shop 3 Jul 7th, 07 05:30 PM
Quarter Window Regulator removal? jrager Interiors 2 Mar 15th, 06 05:45 AM
Rear Window Molding REmoval mybitchincamaro Camaro Tech 4 Apr 9th, 05 04:56 PM
Value of GM window trim & polishing sources ?? Andrew69 Body Shop 6 Oct 22nd, 04 09:39 AM
Rear Window Trim Studs & New Panel 67killerb Body Shop 7 Sep 23rd, 02 10:43 AM
