| Team Camaro Tech Current Topic: 1995 camaro v6 to v8 swap what do i need | ||
| Fourth Generation 1993-2002 |
hey my name is michael i have a 1995 camaro 3.4L with 5spd tranny i was wondering what all i need and need to do, to do it rite please help!!
Check out LS1tech.com.
thanks i want to put A lt1 in it
If you can find the info there its pretty much the same stuff needed. LT1 engine, wireharness for the engine, not sure if you would want to keep the t5 in there with that engine. If you end up swapping the tranny you'll have to see if the crossmembers are the same as well.
Your looking at a hell of a job. Most people just end up selling the v6 and buying a z28 instead. Probally not to much more in the long run. Especially if your not doing the work.
1968 Camaro with a 383 finally done and on the road! |
im doing the work imonly 16 but my dad is a mechanic
Good advice but wrong site
David. Just to start you out, you'll need a new tranny as that one will die behind the lt-1, a new motor (duh), all the wiring, and maybe radiator swapout? Your driveshaft will also have to be shortened. Motor mounts are different. May need to move your exhaust too. |
Similar Threads
| 2 1969 ZL1 Camaro Prototypes | 68Baldwin | Copo & Dealer | 57 | May 11th, 09 06:43 PM |
| 69 camaros on television and movies | jsg1010z | Bench Racing | 30 | Dec 3rd, 07 02:05 PM |
| 69 Camaro rear end swap | Mark69Camaro | Brakes, Suspension & Steering | 15 | Sep 11th, 06 09:24 PM |
| Camaro Swap Meet in Kansas City | csmoyer26 | Bench Racing | 2 | Mar 17th, 06 11:59 AM |
| DIY Network 1968 Camaro Restoration Show | Brentmc | Bench Racing | 2 | Mar 14th, 06 10:41 AM |
