| Team Camaro Tech Current Topic: Power Window Motor Replacement with Window Fully Down | ||
| Fourth Generation 1993-2002 |
On my 2002 Camaro SS - The pass side window lift motor failed with the window in the down position?!
This was an aftermarket motor that i installed maybe a year ago ![]() Every procedure I read described the motor replacement with the window up.. Seems like there is less clearance to get the motor out, but aside from that, it shouldnt matter, should it? Has anybody done this? thanks Scott
1968 Chevrolet Camaro Sport Coupe (96 LT1/T56) 2002 Chevrolet Camaro SS ------ http://www.sdkgarage.com/carpix/68Ca...e/P1010027.JPG |
Its not even funny how many motors my TA burned up in the 7 years I had the car. I think I replaced each side 3 times. After the first I found a model that has a lifetime warrenty so atleast I wouldnt have to pay for the motor each time it went out.
I never had to try swapping the motor out with the window down put Im guessing it would make the job a royal PITA with having to worry about the glass being down there. If it were me I think I would try and get that window up some how once I had the door panel off.
1968 Camaro with a 383 finally done and on the road! |
Mark (AKA Z28 Mark) 1973 Z28 2001 Z28 1974 Corvette Camaros Limited~Nor Cal Club Photogragher Last edited by Z28 Mark; Nov 7th, 06 at 08:34 PM. |
hey guys:
these motors dont last long.. ![]() Mark - I did a replacement on the pass side already..rivets and access holds already drilled out.. It really is not a bad job, just time consuming.. I guess my main concern was having the glass down and in the way, or some other issue that made installation difficult... I did get confirmation that once the motor is removed, I can manually raise the window and prop/wedge it in position..going to try this over the weekend I have seen A1 Auto advertized..I think Autozone has lifetime warrantees as well This guy has a good writeup as well http://shbox.com/page/windowmotor.html Thank you for the help! Scott
Thats the same link I used to help with the process. A very good DIY guide.
I will probably just head to autozone and pick 2 up..call it a day Big fan of that writeup!
Similar Threads
| 69 Power window wiring diagram | Lance-w | Electrical & Wiring | 2 | Apr 11th, 06 08:48 AM |
| Power Window Motor Connectors | Hammered | Electrical & Wiring | 11 | Mar 18th, 06 09:29 PM |
| Power Window door panel on 94 camaro | alotoman | Tech 2000 | 1 | Jun 17th, 01 02:37 PM |
| Power Window motors | Mark Todd | Tech 2000 | 1 | Apr 21st, 01 06:53 PM |
| Power window switches | Robertlana | Tech 2000 | 1 | Mar 25th, 01 10:03 PM |
